RABS
Old May 11, 2002 | 01:36 PM
b737's Avatar
b737
RABS
Where is the RABS valve located on a 88 F150 SB 5.8L. Think i have found the valve but cant locate wire harness??
Old May 14, 2002 | 10:22 PM
madman666's Avatar
madman666
RABS
The RABS sensor is located on the top of the rear axel housing.
Very easy to identify, it’s held in to the housing by one bolt.
Old May 15, 2002 | 05:29 AM
rabidranger's Avatar
rabidranger
RABS
Isn't that the VSS? And if so, does it provide info for both the ABS system and the speedo?
Old May 15, 2002 | 10:19 AM
adelyser's Avatar
adelyser
RABS
Yes, that sensor on the rear axle is actually the VSS, or Vehicle Speed Sensor. Both the PCM and RABS computers use the signal information from that sensor. There should be a RABS valve on the driver's side frame rail, around the firewall area. It should have about 5 wires connected to it.
Old May 15, 2002 | 10:21 AM
adelyser's Avatar
adelyser
RABS
Oh, and rabidranger, the speedo gets it's info from the speedometer drive gear assembly, the VSS is used for speed control signals.
Old May 16, 2002 | 10:53 AM
rabidranger
RABS
Where is the speedometer drive gear assembly? I don't see one coming out of the t-case...
Old May 16, 2002 | 11:03 AM
MustangGT221's Avatar
MustangGT221
RABS
Old May 16, 2002 | 11:16 AM
StrangeRanger's Avatar
StrangeRanger
RABS
You don't have one. On your truck the VSS is on the diff and also functions as the RABS.
Old May 16, 2002 | 11:49 AM
adelyser's Avatar
adelyser
RABS
My mistake, if you have a solid state speedometer, then you're vehicle speed is taken from the rear differential speed sensor. If you have a mechanical speedometer, your speedo is driven from a cable connected to the transfer case tail housing.
Shanemh
Feb 28, 2016 02:59 PM
ekg_80
Dec 16, 2015 08:34 AM
jetdoc
Oct 20, 2015 08:12 AM
krl13
Jul 30, 2008 07:57 PM
