1978 - 1996 Big Bronco
Rebuild Trouble....help please!
Old Sep 14, 2002 | 09:01 AM
RyanGruhn's Avatar
RyanGruhn
Hey people,
I rebuild the 302 I have in my 1983 bronco about 1500 miles ago. My lifters are still noisey, making it sound like a deseil engine and I am still have rings of smoke puff out of my exhaust. Should I be worry about this? And if not, at how many miles should I start worrying?
Ryan
Old Sep 14, 2002 | 09:04 AM
georgedavila's Avatar
georgedavila
I'd worry right now if the lifters are noisy. That means they're out of adjustment or not getting enough oil.
Old Sep 14, 2002 | 09:08 AM
RyanGruhn's Avatar
RyanGruhn
The oils there.....Ill adjust them. What about the smoke?
Old Sep 14, 2002 | 10:15 AM
georgedavila
Is timing an issue? Sounds like it with the diesel running effect. You may have the distributor gear one tooth off.
Old Sep 14, 2002 | 05:05 PM
Pilotrick's Avatar
Pilotrick
What color smoke? White, blue or black? Lifters did you pump them up before installation? Did you tighten the rockers all the way down till they bottomed out? Are you sure you got the right length push rods? Check your plugs for color of tips. Double check your intial timing should be 6 degrees BTDC for an 83. Hope this helps and Good Luck,
Rick
86 302 EFI, bored 60 over, AOD,
Headman Headers, Flowmaster 40 series,
2 inch dual exhaust, MSD ignition
Old Sep 14, 2002 | 05:33 PM
JoeB's Avatar
JoeB
Punisher29073
Nov 10, 2014 09:06 PM
Punisher29073
Jul 6, 2013 12:46 PM
Snowking
Sep 3, 2007 06:23 AM
Snowking
Jan 2, 2007 12:17 PM
