SBF motor mounts
Old Feb 27, 2007 | 02:36 PM
Gary E's Avatar
Gary E
SBF motor mounts
My 5.0 has the stud type motor mounts which stick out to far because of the Volare steering box.
What are the tightest (up against the block) SBF motor mounts to use? And when I go to the parts place what vehicle should I look up?
Old Feb 27, 2007 | 10:55 PM
Grabber's Avatar
Grabber
here is what i did
they are the heavy duty bronco type aftermarket mounts, i am not sure how you have setup your mounts , they where perfect for my application , as they swivel and matched the mount plates perfect, but the picture may help .
Old Feb 28, 2007 | 12:23 AM
nortn71's Avatar
nortn71
Minor question: What year Bronco?
Old Feb 28, 2007 | 04:29 AM
Grabber's Avatar
Grabber
they are from Bronco Graveyard
here is better picture of them.
Old Feb 28, 2007 | 10:40 AM
Gary E's Avatar
Gary E
Ok cool found them here , They just might be the ticket, I bought some 69 mustang ones yesterday but these look tighter, I think I will stick with the rubber since I like it all cushy. and the whole $20 vs $110 It is nice how the poly ones tilt as well.
Old Mar 1, 2007 | 12:08 AM
nortn71's Avatar
nortn71
Thanks for the info!
Old Mar 1, 2007 | 02:22 AM
Grabber's Avatar
Grabber
No problem , i have lined up motor and transmission where i need it , and fabricated a new transmission cross member, when ive just about got this thing nearly together i plan on welding the triangular part of the mount to the body mounts. To remove the motor it will mean all i have to do is undo the centre bolt holding the 2 halves together and pull the motor straight up and out.
Choptopjimmy
Mar 13, 2014 11:01 AM
TxF100
Dec 5, 2009 08:55 AM
reed1951
Apr 18, 2009 04:19 PM
lockley
Engine Swaps
Jan 22, 2005 10:57 AM
