SBF Motor mounts
Old Dec 3, 2009 | 03:49 PM
TxF100's Avatar
TxF100
SBF Motor mounts
Does anyone have a set of measurments/plans for building a crossmenber and the location for installing a SBF (289 Hipo) in a 55 F-100? I have the truck down to the frame and need some help here.
Thanks
Old Dec 3, 2009 | 03:54 PM
Julies Cool F1's Avatar
Julies Cool F1
On my 55 I just used the JC Whitney bolts on to each side of the frame type mounts. It wasn't a cross under support, and they worked just fine!
Old Dec 3, 2009 | 04:05 PM
TxF100's Avatar
TxF100
I was hoping to fabricate my own instead of purchasing if possible.
Old Dec 3, 2009 | 04:52 PM
Julies Cool F1
Well then be creative!
Here's a thread that has tons of links for 289 motor mounts. It might give yousome ideas:
https://www.ford-trucks.com/forums/6...or-mounts.html
Old Dec 4, 2009 | 07:57 AM
GreatNorthWoods's Avatar
GreatNorthWoods
I used 79 T-bird motor mounts and made my own frame mounts when I installed a 302 in my 49 F-1. Maybe this will give you some ideas...
Right:
Left:
Old Dec 4, 2009 | 08:52 AM
kmacht's Avatar
kmacht
I have to ask why you would want to do that. You can get the whole setup (cross member, pads, and bolts) for about $100. Unless you want a non stock height or have a non stock engine you will probably spend at least half that just in material not counting the time it will take you.
Keith
Old Dec 4, 2009 | 04:29 PM
TxF100's Avatar
TxF100
Basically because it free it I fabricate it. I have not cost for materials or labor.
Keith
Old Dec 4, 2009 | 05:57 PM
daves54's Avatar
daves54
if it's free it's for me. I have steel and time, but no money!
Old Dec 5, 2009 | 08:55 AM
GreatNorthWoods
Keith
There's a certain amount of satisfaction that comes with fabricating something useful out of odd stuff garnered from the junkpile instead of ordering it from a catalog. I used part of an old F-1 crossmember on one side and the side of a broken Chinese floor jack on the other. One hundred dollars saved on engine mounts means $100 extra to spend somewhere else where fabrication is not possible....
Jjona5
WTB - Parts & other
Oct 8, 2016 11:50 AM
sonny1965
Mar 10, 2016 04:54 AM
Aaron-71
Jul 27, 2015 09:34 AM
Choptopjimmy
Mar 13, 2014 11:01 AM
