Top Dead Center
Old Feb 27, 2007 | 07:59 AM
junkstan95's Avatar
junkstan95
Top Dead Center
Ok so my 94 2.3L Ranger broke down on the way to work this morning. I got towed back the house and and discovered my timing belt broke. I got the link on here for replacing it, but my question is, how do I verify that my piston #1 is at TDC?
Any other helpful coment would be greatly appreciated as well. Thanks in advance.
Old Feb 27, 2007 | 08:35 AM
fordboy_52's Avatar
fordboy_52
Welcome to FTE junkstan95. Im glad you chose the best site on the net for Ford-Trucks! See you around the boards!!
you can turn the motor over with the starter. have someone bump it and put your thumb over the spark hole. when it gushes and pushes your thumb off you should be on tdc when you align the timing marks on the dampener. this will get you to the correct stroke
Matt
Old Feb 27, 2007 | 02:45 PM
Bob Ayers's Avatar
Bob Ayers
Matt
Since he is re-timing the cam, the stroke doesn't matter on the crank, just TDC. Matter of fact, without the timing belt on it, he probably won't get compression on #1 anyhow.....
Old Feb 27, 2007 | 02:49 PM
fordboy_52's Avatar
fordboy_52
this is true...
Old Feb 27, 2007 | 03:05 PM
jimdandy's Avatar
jimdandy
You will have the crankshaft pulley off anyway. The key that holds the pulley in place is called a Woodruff key. You want the slot that holds this key to be straight up. That will get the piston very close to TDC, close enough for timing purposes. jd
Old Feb 27, 2007 | 03:08 PM
fordboy_52's Avatar
fordboy_52
unless its not on that cycle of the crank. it could be 180 degrees off
Matt
Old Feb 27, 2007 | 03:09 PM
junkstan95's Avatar
junkstan95
thanks guys
Old Feb 27, 2007 | 03:18 PM
Bob Ayers's Avatar
Bob Ayers
Matt
Matt, if the crank was 180 degrees off, the key location would be pointing down.
Old Feb 27, 2007 | 03:20 PM
wtroger's Avatar
wtroger
I always moved the crank to TDC before I removed the pulley and cover. There is a pointer on the cover. And yes the Key Points straight up. Also it cannot be off 180 degrees if the timing belt is broke. Tdc is tdc it can only be off 180 if the timing belt is on. Compression tdc or exhaust tdc is determined by Cam position.
Align all the marks and make sure nothing moves when you let the tensioner tighten and you should be good to go. I would advise replacing that tensioner.
Old Feb 27, 2007 | 03:43 PM
fordboy_52's Avatar
fordboy_52
i dont mean 180 degrees i mean one cycle off.. if its on the top it can be on tdc or one cycle off
Matt
Old Feb 27, 2007 | 03:49 PM
Bob Ayers's Avatar
Bob Ayers
Matt
Matt, the cam turns 1 revolution to the crank turning 2 revolutions. But, in this case, you are aligning the cam to the crank, so you can't be on the wrong stroke (or cycle as you put it).
Old Feb 27, 2007 | 03:50 PM
btooling's Avatar
btooling
ok guys while your on the topic, Is there a mark on the timing belt cover for the mark on the aux sprocket to line up with on an 89 ranger 2.3???? I cant find one, Should it be on tdc along with the crank pulley mark. Does the aux have a shaft that turns another sensor?
Btooling
Old Feb 27, 2007 | 04:06 PM
jimdandy's Avatar
jimdandy
Btooling
Did you get my PM? jd
Old Feb 27, 2007 | 04:15 PM
btooling's Avatar
btooling
Yes Jim dandy but you didnt include the site lol. I hoped you would see the post Im not sure how to Pm yet. It will all work out in the end.
Thanks Hey email it to me cattleman390@aol.com thanks
Old Feb 27, 2007 | 04:25 PM
frankenbroncoII's Avatar
frankenbroncoII
if the belt broke that means the cam wont turn, if you go turning the crank the valves arent opening and closing like they normaly would with the cycle, if you not carefull you can damage a piston.
