Top Dead Center
Old Feb 27, 2007 | 04:30 PM
Bob Ayers's Avatar
Bob Ayers
Originally Posted by frankenbroncoII
if the belt broke that means the cam wont turn, if you go turning the crank the valves arent opening and closing like they normaly would with the cycle, if you not carefull you can damage a piston.
Not the case with the 2.3L. It is a NON-INTERFERENCE engine, so there is clearance between the valves and piston with the piston at TDC, and the valve is open all the way.
Old Mar 3, 2007 | 01:16 PM
junkstan95's Avatar
junkstan95
I cant get the damn crankshaft pulley off...whats the trick?
Old Mar 3, 2007 | 02:13 PM
jimdandy's Avatar
jimdandy
You may need a puller. They are not a press fit, but after they have been on there for a while, they might as well be. A light tapping with a hammer while pulling against it will sometimes break it loose. jd
derek0525
Jan 21, 2017 05:53 PM
fordguy390
Dec 2, 2016 06:49 AM
Nyquil Junkie
Feb 29, 2016 03:30 PM
frank5079
16
Oct 25, 2015 01:34 AM
BIG-COUNTRY
Jul 29, 2006 08:52 PM
