'66 wiper question
In clearing snow, my 'better half' pushed the passenger side down to the bottom of the window and now it does not work at all (DS still works as before).
Guess I gotta fix it now, huh? I know from other posts that I can get to the motor thru the dash cluster, what I need to know is can the linkage be repaired to fix the parking issue, or do I have to drop serious $$$ to buy a new motor?
Thanks for ANY help here,
Al
Mitch
https://www.ford-trucks.com/article/...rd_Pickup.html
This U shaped sheetmetal clip (2) hold the arms to the motor, and may have slipped off or snapped. The bushings in the wiper arms were not available by themselves, but I've used transmission selector lever bushings before from the 50's cars trimmed to fit, and they will work.
IMO, I think you have two separate issues on the same system. First on the passenger side arm. You will have to diagnose if it is stripped, slipped or broken, before we can help with the repair.
Secondly the parking has to do with the motor and the arm on the end of the shaft. I run a 76 two speed, and a delay switch on my truck. If I can get my recall working,....I had some issues to address when I put the motor in my 66. I believe that I had to use the 66 arm on the shaft, because the 76 are wouldn't park with the blades down. That makes me suspect that the motor has been replaced, and the job wasn't properly finished.
I do recall that with the switch connected the motor will park in the same place every time. First thing you might look at is to see if you can flip that arm. There is a nut on the end of the shaft and the arm slips off easily.
Provide a little more info and I think we can get you going.
John
