dim bulb
Old Feb 23, 2007 | 09:08 PM
willydad's Avatar
willydad
dim bulb
the pass rear brake and tail light bulb is noticably dimmer than other one. i cleaned the ground with no improvement. i even cut the ground wire and the bulb still stay lit but of couse dim. where is it getting its ground? again the symptom is same for both filements.
Old Feb 23, 2007 | 10:17 PM
Joms's Avatar
Joms
by removing the ground it seems as if you have a wire hot wire that grounded itself somewhere between the two sides. If the filiment are running both at 50% with the ground unhooked it is telling me that they are hooked in series. If you hook the ground up does one get brighter and the other go away? Check the cables that one didnt rub and touch ground along the harness.....
Old Feb 24, 2007 | 12:11 PM
willydad's Avatar
willydad
the brightness of either filament stays same with ground connected. i didn't mention it before, but first thing i had tried was switching bulbs
Old Feb 24, 2007 | 02:14 PM
willydad's Avatar
willydad
fixed it this morning by replacing socket with new one.
emgee
24
Nov 9, 2010 06:09 PM
willydad
Feb 24, 2007 08:03 PM
fmc400
Electrical Systems/Wiring
Jun 27, 2006 06:38 PM
Rickster63
1997 - 2003 F150
Oct 22, 2003 01:37 PM
petem
Feb 27, 2002 06:03 PM
