Bad ground?
Old Jun 27, 2006 | 06:10 PM
fmc400's Avatar
fmc400
MSEE
Bad ground?
This is actually a '77 LTD. I have funky problems with the passenger side tail light. When the headlights are on and the blinker is on, instead of both bulbs in the tail light going dim and bright simultaneously, the two bulbs switch back and forth (one will be bright and the other dim, then the reverse, and so on). Come to think of it, my '73 Galaxie did that too. Lately the lower bulb doesn't even work. My ground strap is looking pretty nasty so my first thought was a bad ground. However, I have 1.0 ohm resistance between the negative battery terminal and the distributor base...does that mean the ground strap is good?
Old Jun 27, 2006 | 06:38 PM
subford's Avatar
subford
I did not understand ever thing you said but yes you do have a ground problem at the taillight.
abe
Jun 24, 2016 10:12 PM
HoustonDave
Dec 1, 2015 10:06 AM
BakedPotato65
1997 - 2003 F150
Sep 20, 2015 08:57 PM
Onus
Jul 7, 2013 06:02 PM
78bigunns
Dec 11, 2011 08:03 PM
