dim bulb
Old Feb 23, 2007 | 09:18 PM
willydad's Avatar
willydad
dim bulb
the tail lite and brake/signal bulb on pass rear of my 74 is noticabily dimmer than other side. same bulb but different filaments. i cleaned the grond with no improvent. i noticed with ground unhooked, the bulb was still lit. i even cut the ground wire and its still lit. where is it getting its ground from?
Old Feb 23, 2007 | 09:58 PM
stretch351c's Avatar
stretch351c
Check the socket itself. It's possible that the wire that runs to the tailight has a bare spot on it where it goes into it. Or corrosion in the socket might be it. It sounds like you have a bad ground from the tailight wire somewhere in the harness. I'd start with the socket and work my way back to the light switch making sure all connections and grounds are clean and tight. It might take awhile.
Old Feb 23, 2007 | 10:09 PM
plowpusher's Avatar
plowpusher
you are probably grounding through the brake signal light filiment hook the ground back up see if it changes also check the sidemarker light
Old Feb 23, 2007 | 10:28 PM
stretch351c
This may sound simplistic, but have you tried changing the bulb itself? It could be that one of the filaments inside the bulb has broken and is touching the other. Have a buddy watch while you step on the brake pedal and see if there's any change. Make sure you have the tailights on when you do it.
Old Feb 24, 2007 | 12:28 AM
Mil1ion's Avatar
Mil1ion
It takes an 1157 and the offset Pins on the side have to go into the correct slot in the socket or you will get bad things happen.
Old Feb 24, 2007 | 11:55 AM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Need to know a few things...
Which taillamps do you have?
1973 and Early 1974s:
They use a seperate taillight lens and metal lamp housing.
The lights ground through the metal lamp housing.
Late 1974s:
Use a combination plastic lamp and lens housing with seperable plastic lamp sockets.
Used 1974.5-1979
Old Feb 24, 2007 | 12:01 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Here is the Serial Number change pertaining to wiring of the rear lamps:
1973/74 F100/350 Taillamp Bodies.
1973/74 Before Serial # T00,001
1974 After Serial # T00,001
Old Feb 24, 2007 | 12:08 PM
willydad's Avatar
willydad
its a late 74 with plastic housing. first thing a tried was switching bulbs. today i'll try a different socket first and report back. thanks for the ideas so far.
Old Feb 24, 2007 | 02:13 PM
willydad's Avatar
willydad
this morning, i replaced the socket. yes, i am using an 1157 bulb. bulb still comes on without ground connected to body but i noticed the side marker light also comes on when its ground is touched to ground wire for tail/brake light(not yet connected to body ground). maybe this is normal. i was going to take ground screw out for left side but it wouldn't budge. it works ok. anyway, main task was to get pass side as bright as drivers side and it is. so problem was is socket. all it ok now.
Old Feb 24, 2007 | 03:04 PM
Mil1ion's Avatar
Mil1ion
If a bulb can't get ground through its normal place....because everything runs through the T/S switch, it will find ground through another source.
Check for corrosion everywhere around that bulb and socket.
Old Feb 24, 2007 | 08:03 PM
81-F-150-Explorer
Yes this is normal, the lights are finding ground through the TS switch with the ground disconnected.
Glad you got it fixed.
Here are some more suggestions to look for to possibly make your lights even brighter
You can clean up the grounds wire eyelits and where they attach to the body with a little sand paper and some dielectric tune up grease to help prevent further corosion. Use new screws that are not rusted as well etc... Use white lithium grease in the lamp sockets to help prevent corosion.
There is also a ground strap from the engine to the firewall of the truck. Make sure it is clean and tight. Also make sure the ground cable from the battery to the engine, and/or frame is also clean and tight.
hope this helps...
DieHardChief
Sep 4, 2013 01:53 PM
DARYLS88STANG
1997 - 2003 F150
Dec 2, 2012 11:00 PM
willydad
Electrical Systems/Wiring
Feb 24, 2007 02:14 PM
jtharvey
Jan 9, 2006 07:15 PM
