1978 - 1996 Big Bronco
Headlights are totally dead
Old Oct 12, 2002 | 03:19 PM
AngelFire's Avatar
AngelFire
Please can you help? I have a 78 Bronco, all my other lights work fine. Both headlights seem to have a major attitude problem. I just swapped out the switch, and it made no difference. Thanx!
Old Oct 12, 2002 | 06:21 PM
Mil1ion's Avatar
Mil1ion
Not being told what the major problem is,have you checked the dimmer switch?
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Old Oct 12, 2002 | 09:01 PM
AngelFire's Avatar
AngelFire
My headlights don't work, high or low beams, all other lights work fine. If the dimmer is bad, is it hard to change? I have another 78 bronco as a parts truck....thanx
Old Oct 12, 2002 | 09:16 PM
greystreak92's Avatar
greystreak92
Not sure where it is on your 78 but most likely its on the floor to the left of the brake pedal. Otherwise its up on the turn signal stalk. The floor/foot switch is the most likely suspect since its the only other break in the circuit.
Old Oct 13, 2002 | 02:59 PM
AngelFire's Avatar
AngelFire
I'm about ready to give up....
I tried 2 different dimmer switches, and another dash switch,
still no headlights, low or high, any clues, anyone???
Needless to say, the general public was lucky to not of been within "earshot" of me today!!! Quite a bit of cussin' went on!
Old Oct 13, 2002 | 03:44 PM
bronco cam's Avatar
bronco cam
Check your ground wires on your wiring harness.
Old Oct 13, 2002 | 03:53 PM
Mil1ion's Avatar
Mil1ion
Harness must have a break in it.
Start at the left headlight and follow the harness back to the cab testing for continuity every few inches.
[/font]
Old Oct 13, 2002 | 05:15 PM
Mexray's Avatar
Mexray
I had a similar problem in another vehicle with the dimmer switch on the floor.
It was the dimmer switch plastic plug assembly. The metal clips inside were rusty/corroded due to moisture over the years and weren't making good contact.
Replaced the plug and cured the problem! Good luck.
Old Oct 13, 2002 | 05:58 PM
jofa's Avatar
jofa
Iowa-Rob
Nov 7, 2017 08:38 PM
Danny2016
Mar 22, 2017 12:52 PM
mustangpt
Apr 22, 2015 09:59 PM
Dutch123
15
Feb 23, 2007 08:36 AM
