Head lights
Old Mar 21, 2017 | 02:19 PM
Danny2016's Avatar
Danny2016
Question Head lights
I have a 2004 ford f-250 super duty 6.0L. The headlights i have are the two piece set, the actual headlights and the the corner amber lights that go under the headlights. The 2005 F-250 super duty 6.0L has the one piece headlight setthat has the headlights and corner amber lights in one. Will the one piece headlights fit in my 2004 F-250?
Old Mar 21, 2017 | 02:22 PM
2006powerstroke90's Avatar
2006powerstroke90
Direct replacement.
Old Mar 21, 2017 | 02:28 PM
Danny2016's Avatar
Danny2016
I'm sorry does direct replacement mean they would fit?
Old Mar 21, 2017 | 02:39 PM
2006powerstroke90
Yes, they will fit no issue!
Old Mar 21, 2017 | 03:26 PM
87crewdually's Avatar
87crewdually
Somebody should of told the guy in this video then before he cut his headlight panel up for the 2005 headlights to fit.
Old Mar 21, 2017 | 07:07 PM
036.0stroke's Avatar
036.0stroke
I have the new style lights in my 03. You have to trim the header panel quite a bit
Old Mar 21, 2017 | 07:55 PM
VictorwithaC's Avatar
VictorwithaC
Theres some you don't have to for the 03 specifically. I have them on mine they were like 170ish for heads and tails no cutting required one piece like the newer.
Old Mar 21, 2017 | 08:41 PM
Yama4fitty's Avatar
Yama4fitty
Wiring too I believe is an issue for some. Some lights for "conversion" will come with pigtail plug and play adaptors. Not sure what year it changed unless it did when the lights did from two piece to one.
Old Mar 21, 2017 | 08:52 PM
Mike189677's Avatar
Mike189677
You need a 9007 to h13 (9008) adapter harness the bulbs change in 05 like you thought when they went to the on piece light and OP you do have to have to trim the header panel to fit on the 99-04 trucks
Old Mar 22, 2017 | 11:44 AM
Danny2016's Avatar
Danny2016
modify
Will I have to cut or modify anything or will they just plug n play?
Old Mar 22, 2017 | 11:49 AM
Danny2016's Avatar
Danny2016
Question lights
Do you have the brand name of the lights you bought? I have an 04 f250 6.0 will these headlights fit without modifying the the truck at all?
Old Mar 22, 2017 | 12:01 PM
2006powerstroke90
Guess it depends on the brands? The trucks I have done fit no issue
Old Mar 22, 2017 | 12:10 PM
Danny2016's Avatar
Danny2016
Question brand
What brand did you buy?
Old Mar 22, 2017 | 12:22 PM
VictorwithaC
http://m.ebay.com/itm/SINISTER-BLACK-1999-2004-F250-F350-F450-SuperDuty-L-E-D-Headlight-Tail-Lights-/181778412350?txnId=1624168231008
those are what i got. Fitment was pretty good and I didn't have to cut nor get adapters. They use they same bulb as my 03 so your 04 should be the same story.
Old Mar 22, 2017 | 12:33 PM
Danny2016's Avatar
Danny2016
Question design
The 03 and 04's were pretty much the same design weren't they?
