Engine Will Not Start
Old Feb 21, 2007 | 05:51 PM
6POINTO's Avatar
6POINTO
I did a 6.0 swap into a 2000 Superduty. I swapped the entire dash, and harness. Everything comes on with the key, but the engine.
A guy on another board suggested that I unplug the single wire male/female connector on the passenger side of the engine bay and jump the male side of the connector to see if the engine turns over. It runs when I do this, but I can not put it into gear and the accelerator pedal does not work.
What might be the problem?
Thanks
Old Feb 21, 2007 | 07:55 PM
BowTieHatr's Avatar
BowTieHatr
i dont think anyone here will be able to help you because this is way to big. to many wires to just be called wires. if you had everything right, i would think that it would be a no start no a no crank.
Old Feb 22, 2007 | 04:36 PM
6POINTO's Avatar
6POINTO
alright, I finally got the engine to turn over with the key. What I didn't know, or think to check was the position of the arm on the trans. I thought that all the way to the left was park. So, I guess I was probably trying to get it to crank over in 1st? [img]smile.gif[/img]. Now, I just can't get it to come out of park and into gear. And, the throttle still will not work. Is there a way to re-set the throttle actuator somehow?
Thanks
Old Feb 22, 2007 | 04:59 PM
Crash687's Avatar
Crash687
Throttle actuator?? I did not know 6.0 used one, if you have one maybe that is your problem???
Old Feb 22, 2007 | 05:44 PM
6POINTO's Avatar
6POINTO
electronic throttle, there must be an actuator?
Old Feb 22, 2007 | 08:15 PM
BowTieHatr's Avatar
BowTieHatr
no its all electronic in the processor.
XBowhunter
Apr 28, 2014 09:31 AM
locknkey
Mar 2, 2013 08:02 PM
bismic
Feb 3, 2013 02:12 AM
j_lauer
Aug 2, 2010 09:30 PM
wickedklown83
Jul 12, 2010 10:01 AM
