Sponsored by: Real Truck
Wire extra power point to upfitter switch
Old Feb 21, 2007 | 10:22 AM
mr. grieves's Avatar
mr. grieves
I would like to wire an extra power point to one of the upfitter switches and have a few questions not being electrically inclined.
30amp or 10amp, does it matter for a power point, mainly to be used as a cell phone charger?
There is only one wire coming from each switch. How do you hook this one wire to a power point or whatever accessory that has 2 wires?
Old Feb 21, 2007 | 10:54 AM
bneafus's Avatar
bneafus
10 Amp should be fine for a phone charger. The single wire will be the power. The second wire on your outlet goes to a good ground on the frame or body. You'll see a couple of bolts in the frame behind the dash with usually black fires going to them.
Old Feb 21, 2007 | 10:56 AM
CARV's Avatar
CARV
10 amp should be good for cell phone or the like. Power wire from switch to powerpoint. Ground wire from powerpoint to ground on truck. Done Ground on truck should be just about any metal part of the structure you can install a screw.
Boundertom
Oct 21, 2021 06:18 PM
ianc51
Electrical Systems/Wiring
Oct 3, 2009 04:04 PM
ianc51
Oct 1, 2009 05:51 AM
mr. grieves
Apr 4, 2007 09:33 AM
rickppph
Sep 14, 2006 08:22 AM
