Ignition
Old Feb 20, 2007 | 01:17 PM
ckcn10's Avatar
ckcn10
Ignition
Does anybody here use MSD 6 type ignitions on there rigs? I was thinking about buying an offroad MSD 6 for my 5.0 but they are about $250, do you think this is a good investement?
Old Feb 20, 2007 | 01:39 PM
EPNCSU2006's Avatar
EPNCSU2006
Not really worth it to be honest. I have a plain 6A that I got used for 40 bucks and don't notice much of difference between when it is connected and when it's not. Maybe a slightly smoother idle but not really any increase in power.
Old Feb 20, 2007 | 09:21 PM
ckcn10's Avatar
ckcn10
ok, thanks. I have an HO moter that im swapping in a truck, so the truck distributor wont work with the rollar cam correct? i have the distributor that was in the HO, should i just buy a new cap and rotar and then throw that one in there or...?
Old Feb 21, 2007 | 09:01 AM
EPNCSU2006's Avatar
EPNCSU2006
As long as both distributors have the same TFI module configuration (i.e. both remote mount, or both distributor mounted), yeah, just run the HO distributor with new cap and rotor.
Old Feb 21, 2007 | 01:34 PM
ckcn10's Avatar
ckcn10
should i use the stock coil? whats a good coil to use? i have a used blaster 2 coil, if they are good
Old Feb 21, 2007 | 04:14 PM
EPNCSU2006's Avatar
EPNCSU2006
Either one is probably ok. Try both, see which one you like better or if there is really any difference at all.
Old Feb 21, 2007 | 06:44 PM
ckcn10's Avatar
ckcn10
well, if i use the blaster 2 coil i need to cut the plug off for the tfi coil, or i can get a blaster coil from msd that mounts the same as the factory one and has the same plug. what do you suggest?
Old Feb 21, 2007 | 07:48 PM
ken75ranger's Avatar
ken75ranger
The factory TFI coil isn't a bad unit.
Old Feb 21, 2007 | 11:00 PM
EPNCSU2006's Avatar
EPNCSU2006
I wouldn't modify the wiring. Just go with the stock coil.
95F150Guy
72
May 5, 2011 09:39 AM
Khauler
13
Jan 31, 2011 10:28 PM
djmac
Electrical Systems/Wiring
May 8, 2004 12:26 PM
Lee 78F250
Dec 14, 1999 06:11 AM
highlander
Sep 11, 1999 02:11 AM
