1978 - 1996 Big Bronco
squeaking under hood
Old Oct 29, 2002 | 07:34 PM
BOJOFASO's Avatar
BOJOFASO
hey guys
i have a 91 5.8 that just started sqeaking under the hood. ithought it was the belts but it is coming from the back of the engine. when i shut off the engine it still squeaks for a few senconds maybe two second or less. any ideas would be a great help. thanks
Old Oct 29, 2002 | 07:49 PM
Ford_Six's Avatar
Ford_Six
Vacuum leak- almost for sure. Also, check the inlet for the PCV system. If you replace the oil fill cap with a closed type, it will make a whining noise- chased that one for a few days.
Jared
Old Oct 29, 2002 | 08:25 PM
BOJOFASO's Avatar
BOJOFASO
its funny you talk about an oil cap or pvc inlet it started happening after i changed the oil along with a slight oil leak coming from passenger side of engine
. i will check and change the pvc valve and make sure the oil fill cap is vented thanks for your reply
Old Oct 30, 2002 | 10:11 PM
BOJOFASO's Avatar
BOJOFASO
i finally figured it out. it is the fan clutch. the fan spins a few seconds after the engine stops. the squeak stops as soon as the fan stops spinning
Old Oct 31, 2002 | 12:26 AM
Ford_Six's Avatar
Ford_Six
Wow- I never heard one squeak and keep working. I had one on my 'Yota squeak when it blew apart, and one on an F-600 at work just ripped the water pump off, but never a little squeak. I'd replace that before I needed a radiator. Be a good idea to do a pump at the same time.
Jared
Old Oct 31, 2002 | 12:32 AM
mrwizard's Avatar
mrwizard
Old Oct 31, 2002 | 12:59 AM
BOJOFASO's Avatar
BOJOFASO
hey jared
i should replace it. any idea how to tell if it is a thermal or nont
thermal clutch? and can they be interchanged? they are rather expensive if they are thermal.
thanks. do you think i have a little time? say like a week or two
cory5517
May 19, 2013 06:05 PM
06F150Guy
2004 - 2008 F150
Nov 23, 2010 09:58 PM
Spoonboy
May 14, 2009 01:55 AM
nick_wood
General Automotive Discussion
Jul 15, 2005 03:53 PM
fordranger4life
1983 - 2012 Ranger & B-Series
Jul 11, 2004 03:43 AM
