Tranny Fluid Change
Old Dec 28, 2010 | 03:34 PM
makthenif's Avatar
makthenif
Question Tranny Fluid Change
i am quite certain there are numerous threads about this subject. i have done this before but not draining the torque converter. is there simple method to do this?
Old Dec 28, 2010 | 06:02 PM
Gevans17's Avatar
Gevans17
trans fluid change
i dont think the 2002 has a drain plug on the torque converter. You could disconnect the trans line sending fluid to the radiator, attach a rubber hose to that line and place other end in a 5 gallon bucket. Start engine to pump out pan, drop pan and change filter, then replace pan, add 4-5 qts of fluid to fill pan, then start engine and add more fluid as fast as possible while running engine to pump remaining old trans fluid out. Shut of f engine when new fluid comes from hose.
Lawrence Taylor
Engine Swaps
Aug 5, 2017 09:33 AM
Jaime74656
Dec 25, 2015 08:53 AM
wpnaes
Jul 15, 2013 09:18 PM
Trulyvintage
1947 and Older Ford Trucks
May 20, 2011 10:40 AM
HiSPL
Testing.....
Aug 19, 2009 05:52 PM
