Hello, I have a '78 f-100 with a 302 3 speed, I pulled the distributor out and when I disconnected the wiring the plug fell to pieces. The 3 wires from the distributor are orange, brown and black. The wires on the other side look to be orange, blue and green. How can I test to see which wires to connect to each other.
Thanks Judd
thanks for the info, I found that diagram in the haynes book also, the problem I have is that I have the 3 wires from the ignition module colored ppl/blue, blk/grn,and orange. but the wires from the distributor don't match they are orange, brown and black, and I am not sure which wires to hook together.
Thanks Judd
If you decide to get a new distributor, consider our custom curved Duraspark Distributor built with our new Full Length Oil Impregnated Bronze Bushing. The full length bushing improves timing stability and spark scatter. If stock appearance is not an issue, take a look at our one piece D.U.I. Distributor. Whether you choose the Duraspark or the D.U.I., we curve each on a distributor machine based on your engine combination. Please see them at:
