Bronco II Ford Bronco II
Please Somebody Hellllpppp!!!!!
Old Feb 20, 2007 | 05:21 PM
  #31
fl1a's Avatar
fl1a
For info on codes, look at the "read first" thread at the start of this forum.
Old Feb 20, 2007 | 05:38 PM
  #32
b2_tim's Avatar
b2_tim
90Bronco, see my earlier post. I kid you not, that thumb sized coil inside the distributor, activates the TFI module. When it fails your truck stops, do not pass go do not collect $200.
It isn't as easy to change as the TFI, but I have had one fail, and so have others. More infrequently then the TFI, but the same effect.
I replaced the TFI, and coil, before learning of it and replacing. Worked for me, good luck.
Always: Check for spark, check for fuel, check for air before replacing the engine
Tim
Old Feb 20, 2007 | 05:45 PM
  #33
90BRONCOII300,000's Avatar
90BRONCOII300,000
Tim
what is the name of that thumb sized part again?
Old Feb 20, 2007 | 06:30 PM
  #34
b2_tim's Avatar
b2_tim
It is the stator, a coil with some wires attached used to activate the TFI. It lives inside the distributor under the rotor. You have to remove the distributor to replace it. Auto zone calls it a pick up coil part # 184572 F122 on my receipt. $29.99
I hope this helps.
Tim
Old Feb 20, 2007 | 06:42 PM
  #35
90BRONCOII300,000
is there a way to tell if its bad or just replace it and hope for the best?
Old Feb 20, 2007 | 06:43 PM
  #36
Peter94's Avatar
Peter94
i would try the pickup coil. From the sounds of it, just dying all of a sudden like that, and if you have allready replaced the cap, rotor, tfi, etc, then it sounds like the most likely canidate. I would actually pull the cap off of the dizzy and have someone crank the engine, or just jump the termials on the starter solenoid and watch it go around. If it doesnt move when the engine is cranking, then you have problems.
Old Feb 20, 2007 | 06:58 PM
  #37
90BRONCOII300,000
thanks for the help everyone guess ill get to work on it this weekend,,ill keep you posted
Old Feb 20, 2007 | 09:17 PM
  #38
Ken00's Avatar
Ken00
Ford TFI-IV Ignition Troubleshooting
TTDCSB40
Old Feb 22, 2007 | 10:32 AM
  #39
Aggie05's Avatar
Aggie05
Shot in the dark here, but i had somethign similar happen to me and after alot of replacment parts and time, it was a loose connection in some of the wiring harness, found on the passenger side of the engine. ( think it was that side, near the valve covers) wouldnt take but 5 mins to unplug them and plug them back in making sure they are secure.
Tug Hercules
Sep 27, 2012 12:06 AM
HISGTO
Oct 30, 2010 04:58 AM
9.ford.5
Canadian National Chapter
Dec 12, 2008 09:57 PM
Oil-Pig
Nov 9, 2005 02:21 PM
