Bronco II Ford Bronco II
Please Somebody Hellllpppp!!!!!
Old Feb 18, 2007 | 09:56 PM
88FordF-150's Avatar
88FordF-150
Ok so what is ur current status? Whats all the parts you have put in it? What have you tested?
Old Feb 19, 2007 | 07:37 AM
kernel-panic's Avatar
kernel-panic
I forgot about fusible links from the solenoid, however, if the fusible link I am thinking of is bad, it wouldn't even turn over, but worth checking them out. Also check out your fuel pump / ECC relays just aft of the starter solenoid and all of that wiring. Could be a bad ECC relay as well. I'm trying to figure out where you can get an ECM for $35 other than at a junkyard... I think he is referring to the TFI module? I've never heard of a 2.9 grenading a distributor gear, but you can pull the cap and see if the rotor is turning when you turn the engine over. If it is, like someone else mentioned, could also be the distributor guts (hall effect sensor, etc). Also, as previously mentioned, check all of your circuits and the grounds. Going back to the distributor, I do believe I remember hearing about a problem with the ground on the Ford TFI distributors... something about losing continuity to ground and not firing? I don't remember *shrug*
Old Feb 19, 2007 | 07:44 PM
90BRONCOII300,000's Avatar
90BRONCOII300,000
it might prevent the starter from working but will it cut the motor off while its running??
Old Feb 19, 2007 | 07:45 PM
90BRONCOII300,000
used ecm of course
Old Feb 20, 2007 | 01:09 AM
kernel-panic
I guess I was wrong. The '90s I guess have a power box under the hood with fuses in it? Check all of the fuses....
http://www.autozone.com/images/cds/g...3d800f9482.gif
Old Feb 20, 2007 | 01:10 AM
kernel-panic
used ecm of course
Might also be a bad ECM/ECC/ECU whatever you wish to call it.
Old Feb 20, 2007 | 12:06 PM
90BRONCOII300,000
u dont think i changed all those parts without checking the fuse's do you?
Old Feb 20, 2007 | 12:14 PM
OSin86's Avatar
OSin86
Trust me, you can't take a question like that personal with only 9 posts. We don't really know you yet and some people don't check things like fuses before changing parts.
Old Feb 20, 2007 | 12:31 PM
90BRONCOII300,000
didnt mean it in a bad way everyones imput has been greatly appreciated
trust me
Old Feb 20, 2007 | 12:37 PM
90BRONCOII300,000
just want to lean towards the ecm,,, guess i need to be more open for other suggestions too but the way it died suddenly,no noise's,no shaking,,very non violent as if i switched off the key guess i just thought it would have to be computer related but i've definately been wrong before.
(for example)changed numerous parts on my 97 Z28 before finding out it was that damn OPTI-SPARK distributor
Old Feb 20, 2007 | 12:41 PM
90BRONCOII300,000
Thumbs up
90 ford bronco II
97 chevy camaro Z28
99 olds cutlass
98 honda 300ex
00 honda cbr 929rr
Old Feb 20, 2007 | 02:42 PM
Ken00's Avatar
Ken00
It seems like you haven't made any progress so I'll throw my 2 cents in again...
Have you pulled the codes?
Have you run through the TFI ignition troubleshooting guide from the Ford manual? The link to this is in the tech info thread at the top of the forum.
TTDCSB40
Old Feb 20, 2007 | 03:04 PM
  #28
90BRONCOII300,000
TTDCSB40
havent retrieved any codes,having trouble finding link could you help direct me
Old Feb 20, 2007 | 04:49 PM
  #29
frankenbroncoII's Avatar
frankenbroncoII
if it turns out to be nothing electrical, i would bet on a broke timing chain or cam... but you can easily rule this out by taking the cap off the distribute and have some one turn the key, if the button dont move.. then its iether or. if it turns then its not the chain or cam. or dist gear.
Old Feb 20, 2007 | 05:19 PM
  #30
90BRONCOII300,000
what all is involved with the distributor besides cap,rotor another words what are the guts and is there changable parts deeper than cap and rotor?
