GEM replacement
Old Nov 9, 2005 | 11:55 AM
Oil-Pig's Avatar
Oil-Pig
GEM replacement
I have to change my GEM on my 02 X From what I can tell from here it will be located behind my stereo on the firewall. Is this correct? If so can I get it out by pulling the stereo or am I going to have to rip half the dash apart? I would like to get it mounted up and accessable so I can drive to the dealer swap plugs to my new one and have them program my PATS keys to it so I can start my truck after the swap. I just want to save on the clubbings by doing most of the labor myself. I could do it all if it wasn't for the PATS keys.
Does anyone have experience with one of these?
You can see the problems I am having by reading my other post about keyless sleeping.
Thank You!!
Old Nov 9, 2005 | 12:48 PM
remlle's Avatar
remlle
if you need to program the pats keys and have 2 existing keys you can program the new one yourself.
1 stick key 1 (original) in turn to the on position ( not start)
2 wait to a count of 2.
3 turn back pull out
4 stick key 2 in repeat above steps. 2 and 3
5 stick new key in turn to on.
6 pull out
7 test
Old Nov 9, 2005 | 02:12 PM
Oil-Pig's Avatar
Oil-Pig
6 pull out
7 test
This is great if you are using the same GEM and just want to add a extra key, but the new GEM will have to learn both of my keys before it will work.
Thanks Anyway
Old Nov 9, 2005 | 02:14 PM
remlle's Avatar
remlle
ahh ok sorry I miss understood.
Old Nov 9, 2005 | 02:21 PM
Oil-Pig's Avatar
Oil-Pig
Hey no problem thanks for trying anyway
19dcs93
May 10, 2013 11:41 AM
Tug Hercules
Sep 27, 2012 12:06 AM
cigarxtc
May 12, 2011 02:26 PM
HISGTO
Oct 30, 2010 04:58 AM
