No Start!
Old Feb 16, 2007 | 09:52 AM
4running's Avatar
4running
Now the HPOP is whats under the truck below the drivers seat correct? like a frame mounted fuel pump?
Old Feb 16, 2007 | 01:12 PM
4running's Avatar
4running
Gentlemen-
Heres the solution, I removed the line that feeds the fuel pump on the fuel rail, no fuel to be found. I took my air compressor and a rag and pressureized my fuel tank at the filler until fuel was primed at the pump. re attached it as it leaked out, hit the key once, my fuel bowl went from empty to over flowing installed a new fuel filter, and started right up!
I had lost the prime to my fuel pump! I could have cycled that key all day. This Forum is awesome! Between the search function and the guys who posted on this thread you took good care of me, I learned alot today thanks guys!
Kyle
Old Feb 16, 2007 | 01:18 PM
Pocket's Avatar
Pocket
You're not the first person I have seen that needed to have pressurized the tank. I believe that if you run out of fuel, the truck sitting at certain angles will prevent the fuel pump from picking up any more fuel out of the tank. Glad you got it running again.
Also, HPOP stands for High Pressure Oil Pump. It sits directly beneath the fuel filter bowl.
Old Feb 16, 2007 | 02:01 PM
zx250's Avatar
zx250
Of the next Riffraff East
Glad you got it fixed. Sorry I didn't suggest that. Most of time the pump will prime itself. How steep of an angle were you on? It sounds as if you may have some air leaking in around you quick connections between your pump and tank. I had to catch a nap after work.
Old Feb 16, 2007 | 03:11 PM
ponch37300's Avatar
ponch37300
Our trucks only have one fuel pump mounted on the frame. Glad to hear you got it started. If we do the in tank mods would this help with not having to prime the fuel pump?
Old Feb 16, 2007 | 03:19 PM
zx250's Avatar
zx250
Doing away with the quick connection between the pump and tank will help as well the intank mods. The quick connections will pull air and many have done away with these connections to solve the air in fuel problem.
Kwikkordead's Avatar
Kwikkordead
I would think so, but I have never had to put that to the test.
Old Feb 16, 2007 | 03:22 PM
Pocket's Avatar
Pocket
Ponch I'm really not sure. For some reason there seems to be a "bubble" of some sort where fuel cannot be sucked in the pick up feet after running empty. It only happens when the truck is sitting at a good angle. I heard about this a while back before I did the in-tank/pre-pump mods. So I made sure that I backed my truck into the garage as far as I could (without hitting the cab) so that it would sit as level as possible. I didn't want to have to try and sump fuel up once I was finished with the mods.
MoonShine Diesel
Feb 5, 2015 03:59 PM
roy.prue
Feb 11, 2013 10:58 AM
DItR
Jun 20, 2012 10:09 PM
benthere
Jan 14, 2011 03:09 PM
lgalleg7
Feb 23, 2006 07:29 PM
