1978 - 1996 Big Bronco
IAC maintenance question
Old Nov 12, 2002 | 02:04 PM
petem's Avatar
petem
I have a '92 Bronco, auto w/5.0. After I clean the IAC do I need to reset it? If so, what is the procedure? Thanks for any help!
Old Nov 12, 2002 | 05:17 PM
Ford_Six's Avatar
Ford_Six
Nope. The computer does that on every startup and shutdown.
Jared
Old Nov 12, 2002 | 06:38 PM
petem's Avatar
petem
Ok-thanks, but what about setting the idle?
Old Nov 12, 2002 | 06:40 PM
tothfngclw's Avatar
tothfngclw
The idle should reset itself after you clean the IAC. I get a little blowby on my 91 302 and every couple of months mine will act up and I use Valvoline TB cleaner and it works fine after.
Old Nov 14, 2002 | 06:15 PM
petem's Avatar
petem
Great thanks! Gave the IAC a cleaning, but didn't solve the rough idle problem. Back to the drawing board.
Old Nov 14, 2002 | 08:51 PM
fcarruth's Avatar
fcarruth
Have you tried replacing the fuel pressure regulator near the firewall ? Mine was idling rough as well as surging and it took care of it. Only cost about $15. and takes about 30 minutes or so to replace. Either way, it's not a bad item to replace anyway.
Frank
1989 EB Bronco w/302
230,000 miles
Old Nov 14, 2002 | 08:59 PM
Goodsath's Avatar
Goodsath
Rough idle is most commonly a vacuum leak.
Old Nov 14, 2002 | 09:14 PM
christop43's Avatar
christop43
f150plow
Dec 3, 2006 05:39 PM
kameronth
Feb 21, 2005 10:03 PM
Fuggrur
26
Apr 8, 2004 06:47 PM
1990Fordf150v8
Oct 30, 2003 02:56 PM
2fords
Jan 17, 2002 10:08 AM
