1978 - 1996 Big Bronco
New Instrument Cluster
Old Nov 11, 2002 | 02:49 PM
xericx's Avatar
xericx
Old Nov 13, 2002 | 12:48 AM
Riso79's Avatar
Riso79
Has anyone tried hooking up a different instrument cluster? Like, adding an instrument cluster with a tach when the original didn't have one.
Does everything just hook up and magically work, is there a need to run a wire for the tach?
next question is :
What about the mileage, does it read the mileage of the new cluster?
Old Nov 13, 2002 | 10:13 AM
brown 4x4's Avatar
brown 4x4
Replying with *Quote* on the 1st reply is un-necessary
and just adds length to a thread
Yes, a tach cluster of the same style will plug directly in. But be careful, a couple years have different wiring for the voltmeter which could cause charging problems. I'm assuming you have a 92-96. If so, when you have the cluster out, each section (guages, speedo, tach) pops out separately. So you can put your old speedometer in the new cluster to keep the same mileage.
Old Nov 14, 2002 | 11:55 PM
Riso79's Avatar
Riso79
I was specifically talking about a 95 F-150. A buddy has a 95 F150 and the truck had no tach so he purchased a instrament cluster from a 93 or 95 Bronco to replace it with. He bought it for a couple of reasons; he had no tach and the temp gauge was not working and the sensor on the engine has already been replaced. Hopefully this works.
