1978 - 1996 Big Bronco
IAC location?
Old Feb 21, 2005 | 05:42 PM
kameronth's Avatar
kameronth
IAC location?
I am have some idle issues and I was wondering where the IAC valve is located at and what does it look like? Thanks
Old Feb 21, 2005 | 06:44 PM
greystreak92's Avatar
greystreak92
The IAC is mounted to the driver's side of the throttle body. It consists of a solenoid witha two-wire pigtail and a cast alloy valve body that bolts to the throttle body via two bolts with a small gasket between the valve body and throttle body.
Old Feb 21, 2005 | 09:47 PM
JBronco's Avatar
JBronco
It couldn't be easier to replace. Very simple. You could do it in the parking lot of the auto parts store in less than 30 minutes. While you are under the hood, remove the air intake hoses from the TB and clean the TB with throttle body cleaner (be sure that it is safe for throttle bodies).
Old Feb 21, 2005 | 10:03 PM
kameronth's Avatar
kameronth
Ya, that is what i thought it was but I was not sure. Thanks alot!
DadX4
Oct 20, 2010 03:13 PM
moedaddy
1997 - 2003 F150
Apr 13, 2008 01:14 PM
mrossirr
1997 - 2003 F150
Dec 29, 2006 11:40 AM
Tailhunter18
Feb 6, 2005 04:33 AM
2fords
Jan 17, 2002 10:08 AM
