Non-functional OD-off button.
Old Feb 14, 2007 | 10:22 PM
reddog99's Avatar
reddog99
Recently, the Overdrive OFF button in the end of the shift lever has stopped working on my 2004 Ranger FX4. Has anyone else had experience with this? Can I buy the switch or will I be forced to buy the whole shift lever? The truck only has 42,000 on it.
Thanks,
Pat
Old Feb 14, 2007 | 10:34 PM
fflintstone's Avatar
fflintstone
Anything else stop working? might be a fuse?
Is your truck even past warranty?
Fred
Old Feb 15, 2007 | 08:47 AM
reddog99's Avatar
reddog99
Hi fflintstone, I don't think it's a fuse. Everything else works OK. When it started acting up, it was intermittent for a few days before it quit. No warranty either...
Pat
Old Feb 16, 2007 | 10:49 PM
MazdaRangerGuyInSTL's Avatar
MazdaRangerGuyInSTL
There is a small wire going over the steering column to the shifter assembly. It is fastened down by a plastic clip-thingy, and over time from shifting it stretches and eventually breaks.
The wires are a bit too small to attempt repair.. the easiest fix is to replace the shifter assembly (which comes with a new O/D button and lever and all.. not too expensive).. not a major repair at all.
In all honesty, I've yet to see this happen on a ranger, but I've done quite a few on F-series trucks.. but I have a feeling this is what's going on with you.
good luck
Steve Aerostar
Aerostar
Dec 6, 2013 10:10 PM
jerwiltho
Nov 27, 2013 11:44 AM
KhanTyranitar
Aerostar
Nov 6, 2012 08:16 AM
Powerstroke-7.3
May 1, 2011 05:18 PM
rickm5
Aerostar
Sep 26, 2001 10:34 PM
