Tensioner bolt broke
Late last night after mounting the snowplow on my 93 7.3 I parked the truck. When I shut it off I heard a strange sound, when restarted there was a loud belt squeal. Upon investigation I found it had shed the serpentine belt. Fortunately I had a new one , unfortunately the reason it shed the belt was a broken tensioner bolt. Since I had to plow I made a flanged sleeve and found a long bolt that fit, managed to get the broken piece out, and by 4 AM was ready to roll. Ain't snow plowing grand!
Now the question. How often do these bolts break? Was the bolt defective? Break caused by flexing of a loose shoulder bolt? Or is the design faulty and failure common?
I think my fix is good for the long haul, but if it's not a common problem I might get a new bolt and fix it original.
the same thing happened to me about 2 months ago. i was going fishing got about 100 ft away from my house and i heard a loud knocking pulled over looked and found the fan hitting the tensioner i thought the bolt just came loose but nope wasnt that lucky it broke off. i had to drill it out and put a helicoil in its place than replaced the whole tensioner assembly bolt and all. your case is the only other time i have heard of this happening to anyone but me. i remember that when this happened i was reading some info that said in 93 ford recalled the tensioner or the piece it bolts into i cant remember which. well good luck and hope it holds for you.
mike
mike
I had this happen to me about 2 weeks ago. Had a squeal and heard the fan clicking on something. Looked under the hood and the tensioner was cocked over but it had not shed the belt.The lower idler pulley was holding it on. Had to take the bracket loose and got the bolt out from the backside with a pair of visegrips.
jdemaris
15
11-05-2018 07:35 PM
boots6868
07-23-2015 09:43 AM
82bull
06-30-2015 09:37 AM
