'84 6.9 No Start
Old Feb 6, 2007 | 11:57 AM
Schmittys diesel's Avatar
Schmittys diesel
'84 6.9 No Start
Hey All!
My '84 F250 has had a lot of trouble starting lately. If it sits for more than 2-3 days it will act like it is not getting any fuel. I'm guessing i have an air leak somewhere that is letting the fuel drain back. My question is wether or not I can install some type of check valve or shut-off lever so the fuel will not drain back. If so, where should I install it? Return line? after the filter? Any input on this will be helpful
Thanks
Kevin
Old Feb 6, 2007 | 07:58 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Schmittys diesel,
Welcome to FTE and the IDI diesel forum.
Most times this can be fixed by changine the return lines and O rings under the return tees.
Old Feb 7, 2007 | 01:40 PM
Schmittys diesel
Yeah, I recently replaced the o-rings on the return trees..which didn't seem to help one bit. Is it very difficult to replace all the return lines?
Old Feb 8, 2007 | 02:09 AM
Dave Sponaugle
Just replace all the retun lines on the engine.
When I do mine I remove one side, change the O rings, and then rebuild the return tee set for that side. After it is reinstalled I repeat for the other side.
Old Feb 8, 2007 | 02:23 PM
Ben-jamin's Avatar
Ben-jamin
do the line down by the supply pump too.
Old Feb 16, 2007 | 11:00 AM
Schmittys diesel
What about the check-valve or something to that nature?? has anyone ever done something like this?? just wondering.
Old Feb 16, 2007 | 11:52 AM
PLC7.3's Avatar
PLC7.3
No can do a check valve....... You state you only did the orings unfortunately the caps distort too, get a kit. There are numerous other places on the filter header too.
kbuchheit
Jun 25, 2021 11:44 AM
BigRed7.3l
47
Oct 24, 2013 04:40 PM
kevinrea
Feb 6, 2011 06:35 AM
kevbits
Nov 16, 2007 08:02 PM
KevVer
Aug 31, 2003 09:42 AM
