Picking a new Radiator
Old Feb 14, 2007 | 05:52 PM
doug51f1's Avatar
doug51f1
Looking for some ideas on where to get a new radiator. Here's what I have:
51 F-1
289/C4 automatic
Mine has sprung a small leak in the coils and I have no idea what it belonged to originally. I need to replace it and would like to know if anyone has a good source for something that would fit without much modification.
Thanks,
Doug
Old Feb 14, 2007 | 06:12 PM
tip49's Avatar
tip49
Rad source
Doug;
I looked for some time for junkyard replacement from bronco, 70's F150 etc but opted for taking original rad bracket, had new core installed using GM upper and lower tanks, with tranny cooler ports. I'm running 302 with AOD.
Cost was worht it now have new rad, no corrosion, leaks etc.
Tom
Old Feb 14, 2007 | 09:26 PM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
Doug,
Do a search on this site, the topic comes up quite a bit. I used a mid 70/s Dodge truck radiator. There is a great searchable catalog on this site;
http://www.usradiator.com/
That has pictures, measurements, etc
What I did for mine was to scroll through all the different makes, models, etc of all the different cars until I found something that would work for me. Then I punched in the data at the local parts house NAPA, Autozone, Checker, Kragen, etc and ordered the radiator that worked for me.
Good luck
Bobby
Old Feb 14, 2007 | 10:06 PM
Jet Jock's Avatar
Jet Jock
Doug
You might could look at new from Walker or anyone of the other suppliers. Since yours is a daily driver like mine new is the route I would go. Cooling is the number one failure in street rods, and if you are going to depend on the truck to get you to work and back everyday it is worth it.
Old Feb 15, 2007 | 01:21 AM
F100Central's Avatar
F100Central
Great radiator source
Larry at Blue Oval has the right radiator for you. It's the original style and is made for your small block and auto trans.
Here's the web page:
http://blueovaltruckparts.com/catalo...oducts_id=6991
Tell Larry that Chad from F100 Central referred you - if you buy from him.
Blue Oval is also a forum sponsor for this site.
Old Feb 15, 2007 | 06:39 AM
doug51f1's Avatar
doug51f1
Thanks Guys!
Old Feb 15, 2007 | 11:59 PM
CIAF's Avatar
CIAF
DITTO to Jet Jock, don't try to " save" money here for daily drivers. Radiator are so lo cost in comp to other parts, it is great insurance. J
Old Feb 17, 2007 | 10:05 PM
TBucketJack's Avatar
TBucketJack
Try a 3 core modine from a 66 Mustang. Auto Zone has them for around $125.00
Old Feb 18, 2007 | 10:47 PM
halfdone's Avatar
halfdone
I used a 70-79 F100 radiator mounted in front of the support "horseshoe".
I folded two U shaped channels out of sheet and bolted them through the 6 cylinder support holes, then just dropped the rad into them and held it with one bolt at the top.
An hours work, tops............for the second one
In my case I had to notch the rad support for the lower hose, but I have my motor LOW to keep the tunnel ram inside the hood.
Old Feb 19, 2007 | 05:52 AM
doug51f1's Avatar
doug51f1
I ended up going to Summit Racing in Atlanta yesterday and picked up a new "Be-Cool" aluminum radiator. I did some research and with my 289/C4 a drop in radiator turned out to be a downflow with trans cooler for a 55-57 chevy Bel Aire, how funny is that? Any way, they had it in stock so I ran over first thing yesterday and picked it up. Only took about an hour for the swap. All is well now.
Thanks for all the suggestions.
Old Feb 19, 2007 | 09:20 AM
bobbytnm's Avatar
bobbytnm
Glad to hear that it all worked out for you!
Bobby
doug70
Sep 4, 2010 07:40 PM
cldsdl
Jan 30, 2010 01:55 AM
doug2000
Oct 9, 2006 09:04 AM
doug51f1
Sep 9, 2006 12:13 AM
doug51f1
13
Aug 23, 2006 11:54 PM
