busy weekend
Old Feb 13, 2007 | 07:41 AM
F250_'s Avatar
F250_
My guess about the 3" pipe that indebt is talking about is actually a piece of pipe that is 3" LONG... not diameter.
Old Feb 13, 2007 | 08:08 AM
johnsps250's Avatar
johnsps250
I would suspect he is talking about a 3" PVC pipe coupling which has a 4" outside diameter. The reason being is, 3" PVC pipe is 3" inside diameter with a 1/4" wall thickness or 3 1/2" OD The coupling has to be 3 1/2" ID and 4" od.
Old Feb 13, 2007 | 08:13 AM
F250_'s Avatar
F250_
Maybe indebt will eventually enlighten all of our curiosities with an affirmation.
Old Feb 13, 2007 | 08:17 AM
indebt's Avatar
indebt
bingo you explained what my brain failed to do , I had a 4" pvc that would never fit so I figured the coupling would be the ticket since its bigger than the 3" and smaller than the 4" pvc. MY pyro is pre-turbo, the low end I lost is not a big deal since I will order a DP very soon which should bring that back, I really only use my truck for towing and occasional weekend use (motorcycle most of the time) so I too want longevity. Thanks for all the input guys!
Old Feb 13, 2007 | 09:12 AM
ponch37300's Avatar
ponch37300
Alan(amiller93) started to make a setup out of pvc. I have made one but haven't put it on yet, waiting for it to warm up a little. Have access to a heated garage now so maybe all these parts laying around the apartment will start to make there way onto the truck! It is made out of pvc and i think it will work great. I don't know if Alan ever got his installed and might have any more info on it. Here is a link to the post. https://www.ford-trucks.com/forums/5...to-intake.html
bakerbuilttracks
Jun 24, 2013 10:09 PM
timmyboy76
Jun 23, 2011 11:07 AM
swaybar
39
Jan 16, 2009 05:03 PM
foxracing0934
Dec 13, 2008 08:39 AM
mjlewis
40
Apr 1, 2007 08:50 PM
