CCV Mod routed back to intake
Old Sep 30, 2006 | 06:25 PM
Uzumati's Avatar
Uzumati
Well I wanted to keep my boots clean but I didnt want the vapor from the ccv line coming out from under the truck or out of the exhaust. So i built this today.
The line from the CCV runs in on the right and is directed down to help collect the oils then gasses can exit from an interior pipe that has holes cut in it toward the top. Now my plan is to route the output end back to the intake on the pre-filter side. But am wondering if someone knows a reason why I should not return it pre-filter. It will be just as easy to put the return nipple post-filter I was just wanting added protection of refiltering the gasses.
Mod Pics
https://www.ford-trucks.com/user_gal...&albumid=24742
Old Sep 30, 2006 | 07:06 PM
lancer's Avatar
lancer
Nice looking setup. I have like that to except i made it out of steel.As for were to hook it back in i'm sure either way would be fine.
Old Sep 30, 2006 | 07:39 PM
clux's Avatar
clux
I have a similar system, except mine hangs vertically and has a drain petcock on the bottom for the oil, and is packed full of stainless steel scrubbing pads.
I think if you plumb it back in pre filter you will still get enough oil vapor to completely oil up that expensive AIS fliter pretty quick. The oil might affect filter performance and life.
Old Sep 30, 2006 | 08:01 PM
Uzumati's Avatar
Uzumati
Clux that's what i was wondering and why i havent put it in yet. Still time to fine tune the design.
Old Oct 1, 2006 | 04:02 PM
ponch37300's Avatar
ponch37300
Nice setup. This is what i have wanted to do but wasn't creative enough to figure out. Can you just put the return hose back onto the intake pipe in the stock location? Thanks
Old Oct 1, 2006 | 07:36 PM
Uzumati's Avatar
Uzumati
Thats what I am planning on doing now Ponch.
Old Oct 1, 2006 | 07:39 PM
Uzumati's Avatar
Uzumati
I am going to try to fashion a nipple for the pipe I have in the stock location that is not as restrictive as the stock nipple
Old Oct 1, 2006 | 08:22 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
turn it around. make the nipple face towards the compressor wheel.
Old Oct 1, 2006 | 08:25 PM
Uzumati's Avatar
Uzumati
I am Kris I just want to fashion it with a lower profile and narower than the stock setup
Old Oct 2, 2006 | 07:31 AM
mueckster's Avatar
mueckster
I would not face the nipple opening toward the turbo. The air flow would try to draft the oil vapors, just like a blow gun with a suction hose does with solvent for cleaning parts. You could reduce its size, but leave it facing away from the turbo. I have my CCV separator built similar to Clux. I do not get any oil in the nipple or on the compressor wheel. I do drain out the cannister about once a month and find only about a tablespoon of oil. The majority of the oil drains back to the valve cover by the routing of the hose over the brake master cylinder before the cannister.
Old Oct 2, 2006 | 10:23 AM
hansont's Avatar
hansont
I think all these CCV mods are right on the money. However, in the "C" world of engines they didn't want the EGR cooler in the off highway engine series due to oil contamination. Has anybody done an oil analys to see if this is an issue with this version of the mod?
Old Oct 2, 2006 | 01:59 PM
clux's Avatar
clux
I assume you mean dust contamination. My CCV cansiter is completely sealed, no more opportunity for contamination than the factory setup.
My last UOA had 6 ppm silicon with 10,152 miles on the oil, and that's with a lot of dusty dirt road and off road driving.
Old Oct 2, 2006 | 03:37 PM
hansont's Avatar
hansont
Meant it to be more of the pollutant nature than dust. Do a search on EGR cooler and see what Cummins has to say. They are though taking a bit of the exhaust with the EGR I believe, this may be the issue.
Fomoko1
Jan 13, 2007 06:31 AM
slmann
Missouri Chapter
18
Dec 6, 2006 07:38 AM
slmann
Missouri Chapter
17
Aug 11, 2006 08:54 AM
johnny8
20
Jul 15, 2005 08:49 PM
