Need a 10mm wrench to take the one bolt out.
Also may need a screwdriver to help carefully pry out the old one.
Located at about 8 O'Clock if facing the front of the block.
Unplug the sensor
Take out the 10mm bolt
Pry out old one.
Put a film of oil on new one to ease instalation
insert new CPS
Align the metal tab hole with hole in block.
Put bolt back in and plug in.
Your done....
