Stubborn Harmonic Balancer Bolt...
Old Mar 10, 2007 | 08:48 AM
baddad457's Avatar
baddad457
Originally Posted by HemiEater
you can see the dot stamped into the cam gear next to the chain right @ 12:00 in the pic above....it needs to point at the crank gear so the dots line up faceing each other. I posted a pic in the other thread.........
The cam gear is 180* out and that chain looks used.... way too loose........
If he rotates the crank 360* the dots will line up.
Old Mar 10, 2007 | 10:54 AM
HemiEater's Avatar
HemiEater
yup they will... and it will be at TDC of number #1 where he wants to setup the distr....
I just thought he didn't see the dot in the cam gear.......
Old Mar 10, 2007 | 01:43 PM
ReverendMachine's Avatar
ReverendMachine
Thats a New Chain the one before was worse I could almost get it off the sproket. This one has some slack but just enough to get the gear back in place with some struggle. As I understand it, Timing chains are supposed to have some slack in order to keep from premature wear. But hey I'm not sure. lol.
Old Mar 10, 2007 | 01:47 PM
ReverendMachine
Tiger, Bad, Hemi thanks for all your guys' help. Can wait to get my truck back up and runnin lol and to think this all began with what I thought was a bad dizzy. lol. Thanks again.
Old Mar 10, 2007 | 07:33 PM
baddad457's Avatar
baddad457
There should be some slack, just not that much.
PapaBearYuma
33
May 28, 2017 07:17 PM
36545f150
15
Feb 18, 2017 08:13 AM
EDsurvivor
Jun 29, 2016 01:56 PM
littleredford69
1978 - 1996 Big Bronco
Feb 28, 2011 11:02 AM
Nightrain
18
Oct 20, 2010 09:55 PM
