this may be a dumb question but oh well.
i recently changed my lower and upper ball joints. even marking where they should have been placed before, i now need an alignment. last time i got an alignment i was told i needed to get my frame pulled in order for them to get my driver side to it's correct place. that being said i don't really want to waist the 60 bucks on an alignment, get my frame pulled in a month or so then have to get another alignment. would it be too much of a complication for me to do it myself and what would i need to do to get the alignment right?
It's not impossible to do yourself, we do it on racecars all the time. However you're going to spend way more than the $60 on the tools to do it yourself, so if that's all you're worried about it's better just to have an alignment shop do it.
You're looking at probably around $150 for a bubble caster/camber gauge, or upwards of $300 for a digital one. All of them require you to be able to accurately measure turning the tires 20 degrees to the left and right, so you're into it another probably $300-400 for turn plates unless you feel like making them yourself. And, you're going to need something to measure toe-in/outl, so probably another $100-150 for a toe gauge. Though the toe gauge you can make yourself relatively easily.
So... all that to say, unless you're going to be doing it a lot, you're really better off spending the $60 on having a shop align it.
Why would you need to get your frame pulled? Was the truck ever wrecked. If not I would seek another alignment center....
yes it was wrecked but i noticed when changing my ball joints on the driver side instead of putting one of the round things that you move to get it to the place you want it to be they just put a small metal plate which doesn't let it move in and out at all. i'm wondering if my mechanic saw that when doing the alignment. i will just speak to him about it when i bring it in
well that answers everything now without a adjustment collar you cant adjust it sounds like they replaced it with sust a spacer I would take it back to whoever did the damage repairs and make them do it correctly and foot the bill for a alignment...
since it was wrecked and apparently not fixed 100%, i would think an alignment would be in order. on your original question can you align yourself, the answer is yes. i have done my own alignments in the driveway on several cars and trucks over the last 30 years. NEVER been to the shop. i do this with a couple 2 x 2 straight edge boards a $5 level, and a $5 12 ft ruler. This is not rocekt science. How do you think they did it in 1960 before all the super computer equipment was developed. I should say you can do a partial alignment. i also changed out the upper and lower ball joints on a 4 x 4. marek where they were to start and put back in the same space. i then check the toe in and toe out. you can adjust the tie rods to make it right. put a level on the outside of the tire top to bottom and see if it is tipped inward or outward. you can adjust the upper A fram bolts to correct that. you cant do the caster and camber both at home, that would be difficult, but i have found it somewhat unnecessary.
