86 F150 Rear Spring Alignment
Old Sep 30, 2014 | 07:57 PM
samahi72's Avatar
samahi72
On my son in laws 86, I noticed that the bottom spring is not aligned with the upper springs, I would say that it has moved around 1 inch out of alignment. How do you get that spring back to where it belongs? I was thinking that I could raise the body up, support it on the frame, have the wheels fully suspended and then use a block and sledge to hammer it back to its correct position. What do you think?
Old Sep 30, 2014 | 10:56 PM
Gary Lewis's Avatar
Gary Lewis
If you do all you said and then loosen the nuts some you won't have to hammer very hard. But, many of these trucks are running around that way and yours may go back pretty quickly. However, maybe not if you get it straightened up and tighten it down.
Old Oct 5, 2014 | 09:51 AM
samahi72's Avatar
samahi72
Thank you, It seems like there should be some type of clamps that you could put on them to keep them aligned.
TheRooster
Aug 7, 2016 03:38 PM
SPELLY F150
1997 - 2003 F150
May 11, 2008 10:08 PM
the_webers_inc
Jun 26, 2005 10:51 AM
John Kusanovich
1997 - 2003 F150
Nov 21, 2004 08:55 AM
D Harry
Aug 6, 2003 06:24 PM
