Wheel alignment?
Old Jul 28, 2008 | 02:22 PM
H1449-6's Avatar
H1449-6
Wheel alignment?
Getting new tires at Sams tonight and will follow that up with a wheel alignment. Wanted to see if there's a recommendation on the type of alignment I should get for this truck.
Is a front wheel alignment sufficient, or do I need a four wheel alignment? Suggestion on a place to get it done? (Sams doesn't do it). Approximate cost I should look for?
Thanks.
Old Jul 29, 2008 | 09:06 PM
NKENN's Avatar
NKENN
I have my Ex aligned at Firestone. I bought a Lifetime alignment contract. The cost of the contract does not include parts if parts are ever needed. I have the alignment checked about every 10K miles and rotate the tires every 5K miles. Wherever you have it aligned ask for a computer printout of the alignment parameters. I once carried my Ex in for an alignment and they told me it was out of alignment and needed parts. I thanked them and then went and researched the alignment process on the Ex and went back to Firestone and asked for a printout on the readings. Guess what, when they checked it this time it was within specifications. The technician said that he likes to put them "dead on". Well, I wasn't having any tire wear problems or steering problems so I opted to be content with "within specs".
Old Jul 29, 2008 | 10:53 PM
Monsta's Avatar
Monsta
Sit. Stay.
You cannot really do 4 wheel alignment on a truck with a solid rear axle.
A good shop should charge around 90-110 dollars less parts. Adjustment cams may be needed.
Old Aug 2, 2008 | 11:47 AM
H1449-6's Avatar
H1449-6
I wound up getting a lifetime alignment at Firestone for $130.
Old Aug 2, 2008 | 12:02 PM
6686L's Avatar
6686L
Originally Posted by Monsta
. . . . . . You cannot really do 4 wheel alignment on a truck with a solid rear axle . . . . .. .
This whole thread has me confused. Not clear on how you can "align" a 4wd Excursion's rear OR front axles - they are both "solid".
Have you guys figured out a way to abuse your trucks badly enough to bend these axles? Is there some kind of "off-set" king-pin / ball joint thing-a-ma-bob that I dont know about ? I suppose it would be POSSIBLE to BEND a "solid" front or rear axle on a 4wd Excursion out of alignment, but would take some doing....!
Or are we just referring to "toe-in / toe out" checks.
My thoughts are - rotate your tires every 5,000 / 10,000 mi. and run your hand over the tread. If you dont feel or see any "feathering" , "cupping", or other signs of un-even wear, I would think you dont have "alignment" issues.
Old Aug 2, 2008 | 12:25 PM
Monsta's Avatar
Monsta
Sit. Stay.
Yes. Toe-in/toe-out, caster & camber.
there are not provisions for those adjustments on the rear axle.
Old Aug 2, 2008 | 01:14 PM
6686L's Avatar
6686L
caster and camber are adjustable on our four wheel drive "solid" front axles ? Really ? I am willing to learn. HOW ?
Old Aug 2, 2008 | 01:43 PM
Monsta's Avatar
Monsta
Sit. Stay.
Ya know...I think that's only on my 2WD.
Old Aug 2, 2008 | 02:14 PM
H1449-6's Avatar
H1449-6
Firestone claimed they were adjustable and that they were in fact adjusted as part of the service.
If that's impossible based on the truck's design (I have 4WD), please let me know exactly why that is and I'll happily go get my money back.
PS. I went originally because I had some feathering on the front tire. According to the inspection, toe in was out of whack by about a quarter inch.
Old Aug 2, 2008 | 02:25 PM
Immortal_Ben's Avatar
Immortal_Ben
I just had my X alligned at a local Firestone for under $80, been using them for years on various vehicles, and am always happy with the result.
Old Aug 2, 2008 | 03:48 PM
Monsta's Avatar
Monsta
Sit. Stay.
I know I have replaceable cam bushings on top that adjust the caster/camber. I cannot recall if 4WD trucks have them as well since I haven't owned my 4WD Excursion for a while.
Old Aug 2, 2008 | 06:35 PM
jpr38057's Avatar
jpr38057
Camber on a solid front axle is the bend of the beam itself. We actually bend front axles on big trucks all the time. Adjusting casting on a solid front axle requires putting shims under the front spring pads. Caster is adjusted on both sides to obtain a suitable cross caster.
Old Aug 2, 2008 | 08:17 PM
6686L's Avatar
6686L
interesting ! thanks for the info !
Davidjoe
Large Truck
Jan 7, 2016 11:31 PM
Old Coyote
Aug 26, 2015 11:37 PM
OleGrouch
Aug 17, 2012 10:37 PM
greywynd
Nov 21, 2010 10:28 PM
burksj
Oct 16, 2010 09:58 AM
