Sponsored by: Kumho
Brake issue
Old Feb 18, 2007 | 11:20 AM
javi2001's Avatar
javi2001
Picture shown appears also in Haynes 36058 manual, this is not the proportioning valve, this is the metering valve and the tool used to keep this valve open while bleeding is performed to front brakes.
I suggest make a new post with some more detail about your truck configuration and job done, some of us will be happy to help
Old Feb 18, 2007 | 11:47 AM
stuart1's Avatar
stuart1
Correct, it is the metering valve.
On anything under a 1 ton the pin must be pulled out.
1 tons must have the pin pushed in.
I use a small kelly clamp or McGiver whatever is necessary.
Old Feb 18, 2007 | 01:39 PM
eastvanmikee's Avatar
eastvanmikee
I just want to clarify what valve is on my truck before I start a new post so I know Im asking the right questions. This is the valve that is on the frame rail below the drivers feet on a 79 Bronco
So this is a "metering valve" or a "combination valve" ??? If the truck has a 1 ton brake upgrade would you push the pin in or pull out to bleed the brakes? and should I have installed the valve from an F-350 when I upgraded to F-350 booster and m/c ?
Old Feb 18, 2007 | 03:04 PM
stuart1's Avatar
stuart1
That is the valve.
If that has not been changed it is still 1/2-3/4 ton and the pin would be pulled out.
Old Feb 19, 2007 | 07:37 PM
javi2001's Avatar
javi2001
Hey Stuart1, where did you find that picture? any WEB page??? Do you know what is the exact name for the valve marked as "A" ???
Tomcatt68
Feb 21, 2013 10:17 AM
BobbyShane
Sep 24, 2012 09:02 PM
jleo
Apr 4, 2010 01:29 PM
BPuller
Jun 16, 2009 10:42 PM
bigblue
Jul 11, 2003 09:11 AM
