stuck brake bleeders
Old Jul 10, 2003 | 10:55 AM
bigblue's Avatar
bigblue
My brake bleeders on the rear drum assemblies of my 78 F150 are stuck. I can't get them open to bleed the brake lines. I have been soaking them every night for three days with Liquid Wrench, and they will not loosen. Brake fluid is flamable, so I am not wanting to use a torch either. Can anyone tell me how to loosen them???? Thanks. Dan
Old Jul 10, 2003 | 11:26 AM
73Custom's Avatar
73Custom
That's about the best you can do. You're right, heating is a bad idea, it will wreck the seals in the cylinder. Put a good wrench/socket on it and work it back and forth. I ended up twisting mine off and had to replace the wheel cylinders...
Marty
Old Jul 10, 2003 | 11:37 AM
jor's Avatar
jor
They're probably going to break off. Just put a nice tight 1/4 in drive socket on it and be prepared to buy new wheel cylinders. I did the same with a front caliper assemply on my son's 73. Found a nice replacement at the wrecking yard. Good luck (it's only money)
jor
Old Jul 10, 2003 | 01:53 PM
thelonerangerxlt's Avatar
thelonerangerxlt
Dan, if you haven't already twisted it off, try this: With a hammer, tap around the cylinder while applying pressure to the wrench. Also tap on the wrench while applying pressure. Sometimes the hammer blow vibrations will loosen it up. It works sorta like a mini impact wrench.
Old Jul 10, 2003 | 01:55 PM
dfisher1's Avatar
dfisher1
All,
Don't even waste your time. Just buy new wheel cylinders and be grateful they're available.
I put anti-seize on my bleeder screws. It seems to help. I also put them on the wire brush if they are rusty.
A stitch in time saves nine. Your stitch is a little late.
Good Luck,
KingFisher
Old Jul 10, 2003 | 03:24 PM
Jerrybo66's Avatar
Jerrybo66
I've had a little tool for many years called an "impact driver" that's gotten me out of trouble ....It holds any 1/2" drive socket or screw driver head..You would need a reducer to get down to the bleeder size socket...You keep a twist on it and smack it with a hammer...The sharp, twisting jolt, does the work...They're now part of the "made in China" crap but if it gets a guy out of trouble a couple times before it flies apart, it's worth it.....Lots-a-luck...
Old Jul 10, 2003 | 04:49 PM
KJKozak2's Avatar
KJKozak2
Whatever you do, make sure you use a 6 pt socket so you don't round off the bleeder.
I managed to get mine off my 78 with a little work. Although I had the cyl. off the backing plate and taken apart, so I could use a torch.
Good luck.
K.
Old Jul 11, 2003 | 09:11 AM
bigblue's Avatar
bigblue
Thanks for all of the replies!! I tapped on them with a hammer for 3-4 minutes real lightly. Then I pulled very evenly and firmly on the wrench, and they both broke loose. Job completed!!
Dan
CaptainFacePunch
Aug 6, 2015 08:29 PM
mustang_309
Sep 14, 2014 06:16 PM
Iowa-Rob
Oct 17, 2013 08:20 PM
alvald83
Mar 4, 2012 04:46 PM
m350
Oct 9, 2004 07:16 PM
