Sponsored by: Kumho
Bleeding Brakes
Old Mar 20, 2010 | 01:08 PM
jleo's Avatar
jleo
Bleeding Brakes
I just replaced the front brake pads, rotors, and brake lines on my truck. I did touch the rear brakes.
Do I still need to bleed the rear brakes or can I just bleed the front brakes?
<!-- / message -->
Old Mar 20, 2010 | 02:08 PM
Lazy K's Avatar
Lazy K
You will probably get away with just bleeding the front (pass side first).
Old Mar 21, 2010 | 07:54 PM
jleo's Avatar
jleo
Thanks for the reply. I just bleed the front and it worked good.
Old Mar 23, 2010 | 01:45 PM
Lazy K's Avatar
Lazy K
Good man. Glad it worked out for you.
Old Apr 3, 2010 | 12:46 PM
Headviking's Avatar
Headviking
so what is the proper sequence to bleed the brakes?
Old Apr 3, 2010 | 02:38 PM
Lazy K's Avatar
Lazy K
Proper sequence is right rear, left rear, RABS module (if fitted), right front, left front.
Old Apr 4, 2010 | 01:29 PM
Nod's Avatar
Nod
Brake Bleeding
It is always a good idea to bleed the whole system anytime you do break into a closed system.Brake fluid degrades and absorbes impurities and is easy enough to replace with new at these times.Like my Momma used to say"Better safe than sorry".
"bowties in the rearview mirror"
good to doo
Oct 15, 2022 03:19 PM
ford8n47
Dec 22, 2019 06:36 PM
Chevmn56
Mar 26, 2017 01:32 PM
.:1978_Ranger:.
Aug 31, 2014 10:33 AM
jaye
Apr 29, 2010 08:22 PM
