problem #3 in my 1998 ranger
Here's another thread with information on the climate control air flow system:
https://www.ford-trucks.com/forums/s....php?p=2020808
Q2: what is the fix for the two types of failure you quote? I am now banking on these as this is what i experienced today (note i checked the blend door and it's functional, followed vacuum lines wherever i could and no blatant leaks were found) I can even "activate" the vents by manually pushing on the vacuum motor that operates them and that works for a little while, then it defaults back to 'defrost' only mode.
Anyway; here's what makes me believe the vacuum reservoir might be the culprit: I was running the vents as usual (with defrost air function only) then i proceeded to enagage 4-LOW and voila! the vents started working - full stream!-. Stayed that way until i picked up speed/engine load {vacuum} as I got on the on-ramp onto the expressway; then the vents 'shut-off' and went back to defrost mode again.
This is 100% repeatable by the way... what do you suggest ? (where is the check valve in the reservoir? is it a good idea to get a reservoir from the U-pull-it JY???
Thanks in advance.
2. I'm not sure what you mean by "two types of failure I quoted"...?
3. I would be thinking the same thing based on what you've described. Sounds like you have a large vacuum leak or a bad check valve/reservoir. Time to pull the passenger tire and splash guard to take a look. The check valve is inside of and integral to the reservoir.
If you find the check valve to be bad, you might try installing one in the hose that feeds vacuum to the reservoir. You can find them on the rack at most parts stores.
( i said 2 types of failure as you mentioned the vacuum res check valve and the hub vacuum solenoid).. so; which line should i check for vacuum bleed off? (i don't know what the vacuum res. looks like - i actually followed the lines to it today as i installed new front shocks, but did not remove the wheel well plastic/inner fender; only the splash shield)..!
It's been a while since I've looked at mine so I wouldn't know how to explain which hose is which, except to say that the one that runs up to the intake manifold (driver's side of engine, toward the rear) is the vacuum supply line to the reservoir. I suppose you could start the engine and figure it out that way- the vacuum supply line from the intake manifold should have high vacuum at idle.
The vacuum reservoir looks more or less like a small ball with vacumm hoses coming off it. You can't miss it.
