Diesel & Water - Need some pointers.
Old May 2, 2003 | 12:29 PM
jmbatlanta's Avatar
jmbatlanta
I am almost thru my first tank(s) worth of diesel on my newly purchased 7.3 PSD and will be filling up this afternoon.
In reading thru the threads on this forum, it is apparent that water and diesel are not a good mix. My question to the group is are there any pointers I should know about when buying fuel and is there anyway to pro-actively prevent getting water in the tanks. How will the PSD act if I have water in the fuel? and is there a good way to eliminate it? How often should I drain/replace the fuel filter?
Thanks.
Old May 2, 2003 | 01:32 PM
johnsdiesel's Avatar
johnsdiesel
Buy fuel from a station that sells a large quantity. A truck stop is usually the best place if it's convenient. In the winter, try not to let your tanks run to close to empty.
To eliminate water in the fuel, drain the water out of the fuel bowl until you smell diesel. Do this at every oil change.
Ford recommends you change the fuel filter at 15K miles, but I change mine at 10K. By 10K it's looking pretty filthy. When I change my fuel filter I like to completely drain the fuel bowl and fill it up with Standyne lubricity formula.
Old May 2, 2003 | 08:09 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
johnsdiesel gives good advice, but if you really want piece of mind, add a fuel filter with a water seperator in front of the fuel pump. Check out the Vormax in my gallery here
Old May 2, 2003 | 08:35 PM
alanscott's Avatar
alanscott
And don't use any additives that have alcohol in them. If you do, the water will pass through the injectors instead of pooling at the bottom of the filter to be drained out.
Rishsd
31
Jun 6, 2013 06:53 PM
Dieseldriver13
Feb 10, 2013 01:17 PM
curbill4
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Nov 26, 2011 09:04 PM
cmcowboy
Nov 7, 2006 06:29 PM
TooL
Aug 21, 2006 08:27 AM
