need help identifying a part
Old Feb 6, 2007 | 08:35 PM
69cruiser's Avatar
69cruiser
heres my prob step son decided to go crash my truck.So today i started removing the front clip and when i removed the header there's a little box right under the battery on the drivers side with three plugs on it and it has the edge cracked on it . took it of and i can glue together and call it down but i just wanted to know what i was gluing together the id number on kelsey-hayes f81a-2b373-aj rhehfhj 2/350 f81f-2c018-ah thanks again guys
Old Feb 6, 2007 | 08:54 PM
Uzumati's Avatar
Uzumati
Its not the ABS manifold is it. Kind of in front of the batt and below the headlight with several lines comming off it.
For some reason Kelsey-Hayes is bringing up a memory of lighting though. There wasnt a "Bright Box" on there was there.
Old Feb 6, 2007 | 08:59 PM
lionsteve's Avatar
lionsteve
Since I can't delete my post this is what you get...
Steve
69cruiser's Avatar
69cruiser
i believe it is in bolteed to the front of the abs manifold it has 3 plugs on it and about 4inches by 3 1/2 black in color
Old Feb 6, 2007 | 09:12 PM
Uzumati's Avatar
Uzumati
electronic hydraulic control unit (EHCU) is what i am seeing in the servcie manual but its knd of hard to tell from the pic.
PM me your email address and i'll send it to you
Old Feb 6, 2007 | 11:30 PM
69cruiser's Avatar
69cruiser
u think all will be good if i just glue it and call it a day
Old Feb 7, 2007 | 07:39 AM
Uzumati's Avatar
Uzumati
I'll send you that drawing tonight.
If it isnt you will get an ABS Light/Code
Old Feb 7, 2007 | 08:20 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
2B373: Brake Skid Control Valve.
2C018: Brake Proportioning System Control Assembly
Old Feb 7, 2007 | 03:41 PM
69cruiser's Avatar
69cruiser
thanks number got some ca glue and put it back together now i just got to get a new header and a drivers fender and shes all ready
fgadsden75
Nov 15, 2016 06:57 PM
FXDawg
27
Feb 10, 2014 06:36 PM
davidlea
15
Jan 1, 2012 11:56 AM
thepitshop
Nov 18, 2009 07:41 PM
hermanar
13
Aug 16, 2005 09:19 AM
