Tranny Cooler Q..
Old Feb 6, 2007 | 08:27 PM
firemanp's Avatar
firemanp
Tranny Cooler Q..
Has anyone converted an AC condenser into a tranny cooler? I was just thinking of the surface area advantage..
Pat
Old Feb 6, 2007 | 08:37 PM
IDMooseMan's Avatar
IDMooseMan
Interesting idea. I haven't done this, but with the refridgerant and lubricant added to it, I'm not sure if you'd be able to get it clean enough. I suppose it's possible.
If you get it to work without contaminating the tranny fluid, post some pictures and let us know what you did to clean it and all that information.
Good luck.
Old Feb 7, 2007 | 02:02 PM
79_250RangerLariat's Avatar
79_250RangerLariat
I'd stick with a large trans cooler, I think I had less than $50 in mine. Finding fittings to connect the lines to the cooler might be a bugger
Old Feb 7, 2007 | 03:15 PM
aaron o.'s Avatar
aaron o.
My friend uses one as a power steering cooler on his rock crawler. It seems like he has gone through a couple now after they develop leaks. Can't say if its due to flexing or not, but it has never all out "blown out" though. It has definitely made a big difference in the number of pumps fried.
Old Feb 7, 2007 | 03:39 PM
Cuda_jim's Avatar
Cuda_jim
Good idea, with a thermostat tho. It can be cleaned with a tranny cooler flush in a can. Here: http://lifeautomotive.com/faqs/default.asp Bottom of the page.
Without a therm The oil would never get up to operating temp. Tranny needs to get to at least 160 IMO to burn off condensation and allow it to get to optimal design tolerances. Too cold is just as bad as too hot. IMO
Ezalycasaid
May 27, 2016 08:27 PM
cookkd
Aerostar
Oct 5, 2005 08:57 AM
1stBronco
Aug 23, 2005 09:24 PM
streetpreacher
Aerostar
Nov 21, 2004 02:39 PM
bdh
Jul 1, 2002 01:39 PM
