Aerostar Ford Aerostar
Transmission cooler install....
Old Oct 4, 2005 | 11:34 AM
cookkd's Avatar
cookkd
Having finally decided to bite the bullet and install a cooler for my tranny on a 91 Ext 3.0. Initial thought was to run the fluid first through the cooler and then through the radiator. My thoughts were to send cooler fluid to the radiator and that way kill two birds with one stone....cooler tranny and cooler engine. Then talked to a couple of mechanics and they suggested to only use the new cooler and completely bypass the factory one in the radiator. Supposed results: tranny runs cooler and so does the engine....anyone with any thoughts on this?????
Thanks,
Klaus Cook
Houston, Texas
Old Oct 4, 2005 | 11:46 AM
xuzme720's Avatar
xuzme720
your mechanics are right. chances are after being cooled out front in the fresh air, fluid will likely be reheated by running back through the rad. it will negate the benifits of the tranny cooler you just spent cash and time to install. if you do want to run through the rad, just go from the trans to the rad then the cooler letting that nice cool fluid flow directly back to the trans.
Old Oct 4, 2005 | 12:54 PM
96_4wdr's Avatar
96_4wdr
best to bypass cooler in radiator, too many high mileage radiator tranny coolers develop leaks and leak antifreeze coolant into tranny, sudden death and total tranny rebuild, expensive.
go to at least an 11"x11" plate and fin cooler in front of radiator with an inline filter added.
both the A4 and 4R series trannys have an internal thermostat bypass valve that shuts off tranny fluid flow to external coolers until fluid reachs operating temp, abt 150-160d F.
Old Oct 4, 2005 | 01:17 PM
ken1mod's Avatar
ken1mod
see my post on "transmission temperature control"
Ken
Old Oct 4, 2005 | 03:28 PM
Kanute's Avatar
Kanute
Which cooler did you go with?
Old Oct 4, 2005 | 04:36 PM
cookkd's Avatar
cookkd
I went with a Hayden 1405......it's 15.5 x 10 inches....3/4 inch thick.
Old Oct 5, 2005 | 08:57 AM
ken1mod's Avatar
ken1mod
basic thermodynamics, run hottest fluid to the hottest cooler first, radiator, then take the cooled fluid and run it through the air cooled unit in front of the rad. Its called counterflow. use 'em both
Ken
cookkd
Aerostar
16
Jan 28, 2008 03:08 AM
cookkd
Aug 29, 2007 10:27 PM
cookkd
Aerostar
Jun 17, 2007 07:05 AM
cookkd
Aerostar
33
Nov 16, 2005 10:01 PM
cookkd
Aerostar
Oct 12, 2005 07:49 AM
