Stock tranny cooler inlet/outlet and 6.0 tranny cooler conversion questions
Old 06-20-2015, 01:06 AM
Ezalycasaid's Avatar
Ezalycasaid
Ezalycasaid is offline
Wich lines on a stock 7.3 with e40d tranny cooler is the inlet and Wich is the exit? Is the top line the inlet on the stock cooler or the bottom one? Also I got a 6.0 tranny cooler off ebay, but there's no makings on it to wich side is the inlet and the exit? Any way for me to tell? Thanks.
Old 06-20-2015, 07:41 AM
fordman67's Avatar
fordman67
fordman67 is offline
Go down to the trans. The front line is the output.trace from there.the new cooler does not nessarily have a set in/out. Just make sure you plumb it after the rad cooler.
Old 06-22-2015, 10:58 AM
How do I plumb it in after the rad? I was just gonna take off the trans cooler lines and extend them to the new rad cooler. Do u mean physically furthest to the front of the truck?
Old 06-22-2015, 11:05 AM
IDMooseMan's Avatar
IDMooseMan
IDMooseMan is offline
Yes, the line physically closest to the front of the vehicle is the transmission fluid output line.
Old 06-22-2015, 01:05 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,570 Likes on 1,049 Posts
The line from the front of the trans goes to the radiator cooler. The other end of the radiator cooler goes to one end of the 6.0L cooler. the other end of the 6.0L cooler goes to the rear of the trans.
Old 05-27-2016, 01:11 PM
mcali2's Avatar
mcali2
mcali2 is offline
Is that to warm up the line? I'm confused about the reason to send trans line into a hot radiator then to a trans cooler except to warm up the fluid when it is cold.
Old 05-27-2016, 01:12 PM
mcali2's Avatar
mcali2
mcali2 is offline
Also what kind of hose is needed? Mine is old and I'm replacing all rubber everywhere. Do I just use oil line from the Auto parts store?
Old 05-27-2016, 03:46 PM
Mark Kovalsky
The radiator cooler never warms the transmission fluid. I've tested this in ambient temperatures from -40 to +115F.
The trans fluid leaving the trans is HOT. The radiator cooler is on the "cold" side of the radiator. The temperature in this part of the radiator is anywhere from 15F to over 100F cooler than engine temperature. That's plenty cold enough to cool the trans fluid. This is a very efficient cooler, if you remove it you lose a lot of cooling capacity.
Yes, that will work.
Old 05-27-2016, 07:30 PM
mcali2's Avatar
mcali2
mcali2 is offline
So in stock form the trans is cooled.by the radator and a small radator in front of the regular radiator. Im removing the small one and adding the 6.0 cooler
Old 05-27-2016, 08:27 PM
Mark Kovalsky
Yes, that's correct, and the 6.0L cooler is a good move.
squaredancer
11-17-2016 11:03 PM
Lstanley
11-11-2011 10:10 PM
BigWhite94
56
07-21-2010 08:56 PM
kalsc
54
06-18-2009 05:58 PM
bdrummonds
31
04-13-2007 10:31 PM
Quick Reply: Stock tranny cooler inlet/outlet and 6.0 tranny cooler conversion questions
