Kinda funny PSD throttle question
Old Feb 3, 2007 | 07:32 PM
rount5's Avatar
rount5
I'm a newbie and recently switched from a V10 to a PSD. One thing I noticed is that I have to press the throttle pedal down maybe 1/2" or so before it does anything. I'm starting to get used to it but it's kinda strange as I'll be sitting at a green light for a sec or 2 before I get going. Sometimes I get a little too impatient and then it kinda jumps off the line. Kinda embarrassing as I feel like I'm learning to drive a stick shift.
Is this normal for a PSD?
Old Feb 3, 2007 | 08:23 PM
plowhand's Avatar
plowhand
Playing in the Dirt
No, it sounds like your TPS (Throttle Postion Switch) or your ID (Idle Validation) switch is out of adjustment or going bad.
Old Feb 3, 2007 | 08:42 PM
14psd's Avatar
14psd
You better hope it ain't the TPS. THat damn thing is $770.00 (full retail) and you can't buy it alone. You have to buy the whole pedal assembly. If you go to http://www.discountfordpartsaty2kford.com/ they have the wrong one on their website. I called them and asked. They will sell you the correct one a bit cheaper around $600.00. That STILL is a bunch of money for a sensor.....ask me how I know. I found my (new to me) pedal assembly at a salvage yard.....$25.00. Good luck and keep us informed.
Old Feb 3, 2007 | 08:54 PM
jboard's Avatar
jboard
The powerstroke shop sells the whole pedal assembly brand new OEM for 173.00 but i believe the price went up some since i bought mine a monthh ago.
------------Jeremy
Old Feb 3, 2007 | 09:07 PM
rount5's Avatar
rount5
Wow!!! Now it ain't so funny anymore!!! I was hoping it was just an adustment since it only has 36,000 miles on it. Are the TPS known to go bad so soon? Since I've gotten used to it I can start from a dead stop without "jumping", but there's still that first 1/2" that doesn't do anything. I did some searching and couldn't find much on adjustments. Only one was something about making the mounting holes elongated but didn't go into it at all.
Old Feb 3, 2007 | 10:51 PM
jboard's Avatar
jboard
You could try to bend the little tab out. Theres a tab that switches the truck from idle mode to run mode, you will see it it pushes in on a small orange button on the pedal assembly. If you bend it outsome it may fix ur problem. Not too much though because the button still must be pressed in when your foot is completely off the pedal, so the truck idles.
-----------------Jeremy
Old Feb 4, 2007 | 11:04 AM
rount5's Avatar
rount5
Is this TPS/pedal assembly unique to the PSD or is it the same on non-pds models?
Old Feb 4, 2007 | 12:49 PM
jboard's Avatar
jboard
It is unique because everything on the engine is electronically controlled it requires a fully electronic pedal. No throttle cable. so you wont be able to swap in a gasser or an old IDI pedal. It simply wont work.
------------jeremy
Old Feb 5, 2007 | 01:29 AM
DAVID'S97F250HD's Avatar
DAVID'S97F250HD
$770...............what the hell, damn and mine was acting up in the fall, hardly driven the truck this winter so I have forgotten about it. I think its best I forget about about it for now.
Old Feb 5, 2007 | 10:30 AM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Former Vendor
14psd's was a 94-95, the 96-97 I sell for $215.94 different years take different parts.
but still big bucks either way!
Ed
Old Feb 5, 2007 | 02:42 PM
rount5's Avatar
rount5
Ed, thanks for the update!!! Still bucks but much less. I'll do some more testing, etc and get back to you on this if I still need one. I disconnected the batteries for a while to reset the computer. Seems to be a bit better but need to drive it some more.
Ed
Old Feb 5, 2007 | 02:43 PM
MPlayer's Avatar
MPlayer
Mine went out last August. It is a '95 but I bought a '96-'97 pedal assembly and it worked. Don't ask me what the difference is but it worked in mine. The part numbers on all the components on the pedal assembly were the same. Hope this helps.
Old Feb 5, 2007 | 04:01 PM
Parts Guy Wyatt
Former Vendor
cool, let me know.
Ed
Old Feb 7, 2007 | 03:57 PM
1969fordguy's Avatar
1969fordguy
<HR style="COLOR: #666666" SIZE=1>
<TABLE><TBODY><TR><TD vAlign=top width="100%">I'm a newbie and recently switched from a V10 to a PSD. One thing I noticed is that I have to press the throttle pedal down maybe 1/2" or so before it does anything. I'm starting to get used to it but it's kinda strange as I'll be sitting at a green light for a sec or 2 before I get going. Sometimes I get a little too impatient and then it kinda jumps off the line. Kinda embarrassing as I feel like I'm learning to drive a stick shift.
</TD></TR></TBODY></TABLE>
Um, I may be the only one that noticed this, but our throttle pedals are touchy! There may be something wrong but I wouldn't be suprised if the pedal was fine. It takes some getting used to.
robandrhonda
13
Apr 21, 2020 08:48 PM
Strokerboy73
Oct 23, 2015 04:37 PM
KDAVID1
Aug 30, 2015 07:48 AM
Seth2w
Jul 6, 2015 11:29 PM
Racin07jason
Sep 11, 2012 12:29 AM
