turbo question
Old Feb 5, 2007 | 08:30 PM
ultramag's Avatar
ultramag
turbo question
i have heard that there are some bolts on the turbo that can work loose.where are these bolts on the turbo and what can be done to fix them.my truck is a 2007 f350,drw. but the engine is labled as a 2006 6.0
Old Feb 5, 2007 | 10:24 PM
6L PWR's Avatar
6L PWR
New one on me. I haven't heard of this issue yet and I've been through these forums and others MANY times for the past year.
Old Feb 5, 2007 | 10:33 PM
vloney's Avatar
vloney
Most generally, the bolt I've found loose, or missing is the 10 mm head one on the passenger side of the turbo.
Old Mar 14, 2007 | 07:49 PM
wpgf250's Avatar
wpgf250
I just found this past weekend that 2 bolts on the air intake side of the turbo had completely fallen out. A third bolt was 3/4 of the way out. The bolts were at 10 o'clock, 12 o'clock and 3 o'clock position. I could see that the o-ring had been blown out. I loosened the bottom 3 bolts slightly, split the case a bit and pushed the o-ring back in as a temp fix. Is this o-ring available? I found the missing 2 bolts on the bottom of the valley pan. They looked like they were there for some time. I am back to having boost again, but do need to replace the case o-ring if possible.
TheBEATTIE
Feb 5, 2015 11:50 AM
AGE mechanic
Aug 18, 2011 07:47 AM
Nick 99
28
Oct 5, 2009 06:25 PM
Vinford
Dec 23, 2008 05:26 PM
tjbeggs
Nov 11, 2005 09:03 PM
