I replaced the belt tensioner and will say the new one has twice as much torque as the stock unit. The belt has no rebound now.
When it rains it pours,after I got the new tensioner put on & belt I got to start the engine and it cranked like it wasn't going to start. Come to find out the original alternator gave up the ghost and had to install a new one of those,it's been an adventure!
So you replaced the tensioner, belt, and alternator? And now you have no more vibration?
I replaced my alternator about 15,000 miles ago. I still have the stock tensioner and an old belt. May be time to change.
I replaced the belt before the tensioner which did nothing for the vibration,did the tensioner and found the alternator was toast at the same time.
I spoke to a couple folks and stated that the alternator may create noise/vibration when they go belly up. Could be a 50/50 for the aternator and tensioner for the vibration is gone.
The new alternator is fantastic but the HPOP can't keep up now with the cranking speed
