Sponsored by: Auxito
4.2 V6 Vibration problem
Old Feb 2, 2005 | 12:11 AM
Greymon's Avatar
Greymon
Question 4.2 V6 Vibration problem
Hi all, first post so bear with me.
I have a 98 F-150 4.2 V6 Auto 4X2 with 107K miles on it. As of late when stopped with truck in gear, there is a very pronounced vibration that can be felt through the brake peddle and steering wheel. The vibrations have at best been slightly noticable, and at other times have been so bad that it it can rattle the dashboard. When in park and running at idle, there is no problem, netural same thing no trouble. But step on the brake and put it in gear, either forward or reverse and the problem starts. Same when comming to a complete stop at a light or stop sign.
I have not noticed any slipping when driving. And the vibration does not seem to happen when the truck in moving. The truck was just tuned up and fuel filter replaced by the dealer at 100k, and the trans and rear end fluids and filters were changed at 70K. The check engine light is not on, and the idle stays constant, and it does not stall or hesitate when stepping on the gas.
Any idea's or suggestions would be helpful.
Old Feb 2, 2005 | 06:00 AM
MBDiagMan's Avatar
MBDiagMan
It is somewhere between extremely difficult and totally impossible to troubleshoot noises and vibrations over the internet.
That said, it sounds like there is an idle problem since it happens with a slight load. I would start by putting on a vacuum gauge. If it is showing a low vacuum, I would check everything that could cause a low vacuum most importantly the EGR valve.
If there is a good vacuum, I would clean the Idle Air solenoid and the throttle body.
Hope this helps,
Doc
Old Feb 2, 2005 | 07:57 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Greymon.....Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
We are pleased you have chosen the best source for Fords!
Enjoy FTE
..See you on the boards.
Jimmyk111
Modular V8 (4.6L, 5.4L)
Jan 9, 2017 10:19 AM
nvann001
1997 - 2003 F150
Nov 29, 2016 12:24 AM
Jeff396
Jul 22, 2012 09:20 PM
pit_of_pity
17
Mar 24, 2011 04:50 PM
Greg A R
Feb 3, 2011 03:55 PM
