release ignition switch
Old Jul 29, 2007 | 12:47 AM
warthog5's Avatar
warthog5
Get 2 made.
Old Nov 6, 2007 | 02:29 PM
bullnbc's Avatar
bullnbc
i have an 89 f250 need to remove ignition but have lost keys is there anyway i can get the tumbler out without having in on position
Old Nov 6, 2007 | 02:35 PM
quicklook2's Avatar
quicklook2
not as easy with no key.
you have to drill some parts out.
Old Nov 6, 2007 | 02:36 PM
bullnbc's Avatar
bullnbc
Originally Posted by quicklook2
not as easy eith no key.
if it was i wouldnt be asking for help
Old Nov 6, 2007 | 02:38 PM
bullnbc's Avatar
bullnbc
sry little fustrated at the moment ant help appreceited
Old Nov 6, 2007 | 02:39 PM
quicklook2's Avatar
quicklook2
i was trying to find a description of how to drill it out.
this is for 92-96 but it should be close to what you need to do:
no pics but this is how to do it:
i posted before how ford manual says to do if key broke off or lost keys to get cylinder out. here it is again:
-disconnect battery ground cable.
-remove steering wheel.
-using channel lock pliers or vise grips, twist lock cylinder cap until it seperates from the lock cylinder.
-using a 3/8" diameter drill, drill down middle of ignition key slot approx. 44mm (1-3/4") until lock cylinder breaks loose from breakaway base of lock cylinder. remove lock cyl. and drill shavings from the lock cylinder housing.
DO NOT DRILL TOO DEEP!
-remove retainer, washer, ignition switch and actuator. thoroughly clean drill shavings and all other foreign materials from casting.
-carefully inspect lock cyl. housing for damage from the above operation. if damage is apparent, housing must be replaced.
install your lock cylinder.
good luck!
__________________
Old Nov 6, 2007 | 02:51 PM
bullnbc's Avatar
bullnbc
thanks i was afraid of that will wait see if any body else has better solution but if not ill do that thanks for the help
Old Nov 6, 2007 | 03:17 PM
danr1's Avatar
danr1
Did ya try turning it without the key, I've found many fords will start/turn without it once the tumbler is old and worn enough. A screwdriver or "any" key will work sometimes also.
Just swapped the one in the 88 b2's, couldn't turn it with the key in it. Fought with it with the key in for several minutes with no luck. Had to laugh, took out the key and it turned easily as if it had the key in it. Almost left it like that but already had the tumbler out of the other one and ready to go in next to me on the seat.
IF not, force it with a large pair of channel locks.
My plow truck will start with the key, can be a pain now and then sometimes and also starts without the key. Now and then I'll be driving down the road and notice, I didn't put the key in it!
Old Nov 6, 2007 | 03:28 PM
TheRoadVirus's Avatar
TheRoadVirus
I had to use the actuator rod itself with vice grips shortly before I put my truck away because something broke when it got really cold out. When I went to turn the key it got harder and snap, weee. Would that likely be the cam gear or whatever? What's the process to do this job?
Old Nov 6, 2007 | 06:10 PM
bullnbc's Avatar
bullnbc
well i drilled out the key hole enough to remove tumbler pins got ignition tumbler turning to run position
but when i stick small rod in hole to release tumbler i still cant find release pin
Old Nov 6, 2007 | 06:25 PM
danr1's Avatar
danr1
"but when i stick small rod in hole to release tumbler i still cant find release pin"
You can't find the release or pushing it in doesn't release it?
The pin is flush with the outer edge of the hole until pushed in to release it. It may, or may not slide out easy once released, For me one did the other a screw driver freed it.
tinman52
Nov 15, 2013 10:50 PM
beckman
Feb 22, 2013 09:55 PM
justplumducky
Aug 28, 2010 08:24 PM
hosemandc
18
Mar 25, 2007 09:50 AM
gwp36530
May 15, 2004 08:39 PM
